Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
956 Discussions
Programming the I210 using EEUPDATE
mederic
Good Afternoon,
I'm working on the redesign of a board that hold the I210 controller using Windows 10 64bits.
I'm looking for the EEUPDATEW64e.exe tool in order to run it and show the adapter connected.
May you please provide me the link to download it.
example :
C:\EEUPDATEW64e.exe
Then I'll be able to program the I210 component and the definesits MAC Address using the below command :
C:\EEUPDATEW64e.EXE /NIC=1 /D binaryfile.bin /MAC=MACaddress
Thanks for your support.
Méderic.
CarlosAM_INTEL
Hello, @mederic:
The Intel(R) I210, I211, and X550 EEPROM Access Tool [EAT] document # 572162 is the tool that may help you. It can be found when you are logged into your Resource & Design Center (RDC) privileged account at the following website:
http://www.intel.com/cd/edesign/library/asmo-na/eng/572162.htm
The RDC Account Support form is the channel to process your account update request or any inconveniences with the provided website. It can be found at:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
@CarlosAM_INTEL.
mederic
Hello @CarlosAM_INTEL
I tried to get access to the link your provided me but my account status for Resource & Design Center is still pending (Not Authorized to Access).
Is there another way to reach the link you provided me ?
I also have two binary :
- In the past we used : Dev_Start_I210_Copper_NOMNG_8Mb_A2_3.25_0.03.bin
- Now we are using : Dev_Start_I210_Copper_SMB_8Mb_A2_0.03_3.20.bin
Is these binay file that come from Intel, do you know the difference ?
Regards.
Mederic.
mederic
We found on our network and install the version of EEUPDATE v5.19.25.00
- Using the command line EEUPDATEW64e.exe (refer to the attached Screenshot1.jpg), the board is detected.
- Using the command line EEUPDATEW64e.EXE /NIC=1 /D Dev_Start_I210_Copper_SMB_8Mb_A2_0.03_3.20.bin /MAC=xxxxxxxxxxx
It failed with the error « Flash region protected » .
Is it because we are trying to program an I210 component that is still programmed (do this means that It should works with a Blank device) ?
- This is confirmed using the command line EEUPDATEW64e.EXE /NIC=1 /IDFLASH
We got the return "Shared Flash image update FAILED! Flash region protected" (refer to the attached Screenshot2.jpg).
Mederic.
CarlosAM_INTEL
Hello, @mederic:
Thanks for your reply.
The information requested required that you have a Non-Disclosure Agreement (NDA) signed with Intel provided it to you, so the RDC privileged is needed to have it.
Due to this fact, feel free to use the form to request more details of your RDC privileged account update request.
@CarlosAM_INTEL.
mederic
Hello @CarlosAM_INTEL ,
Thanks for your reply, we have a NDA signed therefore my account should be granted shortly.
Waiting that, are you allowed to provide me answers ?
Méderic.
mederic
Hi @CarlosAM_INTEL
I already create an IPS ticket on the below link, this confirm that the NDA is still created :
https://premiersupport.intel.com/IPS/5003b00001TFeO5
Méderic.
CarlosAM_INTEL
Hello, @mederic:
Thanks for your replies.
We have contacted you via email with suggestions that help you in the best way possible.
@CarlosAM_INTEL.
mederic
Thanks for your message and the email received.
I’d like to create a new case on IPS for my query that concerns the component I210, but may you please tell me what I have to write in « Search Product » ?
Méderic.
CarlosAM_INTEL
Hello, @mederic:
We have answered your previous message via email.
@CarlosAM_INTEL.
mederic
My RDC privileged account has been updated, I do now access to the support.
May you please help me to solve this topic please.
Méderic.
CarlosAM_INTEL
Hello, @mederic:
Could you please clarify that you have followed our suggestions stated in our email of the last  August, 4th, 2020?
@CarlosAM_INTEL
mederic
I'm sorry I do not understand the question, may you please tell me what to do or what are you looking for ?
I have created an IPS ticket, but we told me that it is not appropriated for that issue because IPS concerns only FPGA.
The GE NDA was validated that allow me to have access to support.
Méderic.
CarlosAM_INTEL
Hello, @mederic:
Thanks for your update.
We have sent an email that may clarify this situation.
By the way, please remember our previous suggestions related to the tool stated in your last communication via the community.
@CarlosAM_INTEL
mederic
I received the email.
Regarding the Tool suggested, it is only compatible with Linux.
As I'm working on Windows 7 or Windows 10 may you please suggest me a compatible tool.
Méderic.
CarlosAM_INTEL
Hello, @mederic:
We have sent another email to help you.
@CarlosAM_INTEL.
