Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
931 Discussions
Question on programming of Intel 82574 external flash with eeprom access tool
HLim01
I have an existing card having a WS82574 Ethernet chip with an obsolete SPI Flash ATMLH726 as its NVM.
I dumped the image of the flash with the EEPROMAccessTool with the following command :
sudo ./EepromAccessTool -dump -NIC=1
The dumped image file is 32kbit and has MAC address at the start address.
Then I replaced the ATMLH726 with a Microchip SST25VF010A 1Mbit SPI flash and tried to write the dumped image file back to  the blank SST25VF010A flash with the command :
sudo ./EepromAccessTool -NIC=1 -f=filename.otp
. Thereafter I execute command
to check if the programming is successfully. The return dump image file has all 0XFF as its content, indicating the content is still empty and the programming is not successful.
Please forward this email to relevant party to advise the cause of failure.
Lim Hui Peng
CarlosAM_INTEL
Hello, @HLim01​:
Could you please clarify if this forum is a duplicated of the thread stated in the following website?
https://forums.intel.com/s/question/0D50P00004NrU70SAF/question-on-programming-of-intel
We are waiting for your clarification.
@Mæcenas_INTEL​.
HLim01
Yes, it’s a duplication. Best Regards, Lim Hui Peng Senior Member of Technical Staff DSO National Laboratories Contact No : 65-68712574 Email : lhuipeng@dso.org.sg
