Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
918 Discussions
Questions about HW on I210 Ethernet Controller .
YKiku
When "I210 Ethernet Controller" is not used, is the pin no problem with "1-4"?
  1. PECLKP /N    :25pin,26pin ⇒NC
  2. PE_RP /N      :23pin,24pin ⇒NC
  3. PE_TP /N      :21pin,20pin ⇒NC
  4. PE_RST_N    : 17pin ⇒PD 10kΩ
Adolfo_S_Intel
Hello @YKiku​  I am investigating your case, I will provide more information as soon as possible.
Adolfo Sanchez
Adolfo_S_Intel
Hello @YKiku​
The engineers state that no PCIE pins can left unconnected, they also want to clarify what do you mean by "I210 Ethernet Controller is not used", what feature is not being used?
Adolfo Sanchez
YKiku
​Thank you for reply.
I want to make 1port of 2port HW Ready.
I asked this time because I want to mount the IC and make it usable by remodeling.
If so, are there any problems with pins 1-4?
  1. PECLKP /N    :25pin,26pin ⇒PD 10kΩ
  2. PE_RP /N      :23pin,24pin ⇒PD 10kΩ
CarlosAM_INTEL
Hello, @YKiku​:
Thanks for your clarification.
It is important to let you know that the mentioned configuration is invalidated because all PCI lines must be attached.
@Mæcenas_INTEL​.
YKiku
Hello , Intel Team,
I understand that PCIe requires all connections.
Please tell me last.
Stay in the RESET state,
does termination of the PCIe lane cause the IC to break in the short circuit?
Or there is no short circuit failure,
Not recommended because PCIe not connected is not assumed?
CarlosAM_INTEL
Hello, @YKiku​:
Thanks for your reply.
All PCI lines must be attached for the part to work properly.
@Mæcenas_INTEL​.
YKiku
I understand.
