Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
916 Discussions
Regarding programming of i210
pTG00
we are using i210 chip in our ls2088a arm based development board through PCI interface, we need to program binary to i210 via pci from ls2088a board since lanconf is available only for x86 and x64 platform, can we get lanconf for arm platform or can we cross compile it
CarlosAM_INTEL
​Hello, @pTG00​:
Could you please try to use the Intel I210, I211, and X550 EEPROM Access Tool (EAT) document # 572162 and let us know the results? It can be found when you are logged into your Resource & Design Center (RDC) privileged account at the following website:
http://www.intel.com/cd/edesign/library/asmo-na/eng/572162.htm
The RDC Account Support form is the channel to process your account update request. It can be found at:
https://www.intel.com/content/www/us/en/forms/design/contact-support.html
We are waiting for your reply.
@Mæcenas_INTEL​.
pTG00
Hi Maecenas, We are able to cross compile the EepromAccessTool and able to execute in our board but we are facing issue to detect i210 in this tool attaching screen shot for your reference.
CarlosAM_INTEL
Hello, @pTG00​ :
Thanks for your reply.
The only tools we have available for ARM is the EAT.  Intel does not currently have plans to provide the other tools for the ARM CPU’s.
@Mæcenas_INTEL​.
pTG00
Hi Maecenas, Thank you for the information, EAT tool is not detecting i210 in arm chip, have you tested this tool in any ARM chip if yes can you please provide the details.
CarlosAM_INTEL
Hello, @pTG00​:
Thanks for your clarification.
The information that may help you is stated in the answer to the question 2.23 ,on page 9 of the Intel(R) Ethernet Controller I210/I211 Frequently Asked Questions [FAQs] document # 335346 that can be found at:
https://www.intel.com/content/dam/www/public/us/en/documents/faqs/ethernet-controller-i210-i211-faq.pdf
@Mæcenas_INTEL​.
