Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
931 Discussions
Hello, Carlos Our processor unit is: imx6q, PI7C and 4x i210.  Each i210 requires 8Mb for PCIe BAR0. Is it possible to reduce memory limit for BAR0. Ilya Lyakh
ILyak
CarlosAM_INTEL
​Hello, @ILyak​:
The information that may help you is stated in section 9.3.11, on pages 592, 593, and 594 of the Intel (R) Ethernet I210 Datasheet document # 333016. This document can be found at:
https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/i210-ethernet-controller-datasheet.pdf
@Mæcenas_INTEL​.
ILyak
Hello, dear Maecenas Thank you, Maecenas I had finished the issue last week. Best regards Ilya Lyakh ELARA Moscow 08.04.2019 22:08, Intel Forums пишет:
ILyak
Hello, dear Maecenas.
My curent sulution is to write 0x8200 value to BARCTRL register (default value is 0x8700). This BARCTRL register is r/w (i210 Chapter 8.6.12) and reserved but it's the only solution to start with imx6q/PI7c/4xi210 configuration. The reason to write BARCTRL is imx6q hardware PCIe I/O memory 16Mb limit. IGB kernel module and EEPROM Access Tool can't start without reduced BARCTRL.FLBARSize = 010b ( 512Kb I/O memory). Default value BARCTRL.FLBARSize = 111b ( 16Mb I/O memory).
Thank you.
Best Regards.
ILyak
The BARCTRL register is marked as reserved in i210 datasheet. Is it dangerous to write to BARCTRL?
I have no other working solution.
Thank you.
Best Regards.
CarlosAM_INTEL
Hello, @ILyak​ :
Thanks for your reply.
You should set the LAN Boot Disable bit in word 0x24 to disable the Expansion Rom Bar.
Flash Bar Size can be edited in word 0x28.
@Mæcenas_INTEL​.
