Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
855 Discussions
Setting 1 Gb No auto negotiation with Lan Conf (Quartzville tool pack)
DUrfj
Hi. We have goten access to Lanconf tool (part of Quartzville tool pack) from Intel. We have an issue with an 1Gb fiber link where we must turn off auto-negotiation completely. We hoped we could do this with the Lanconf tool but it seems like the selection we need is missing. We use the Lanconfw64e.ece /Textmode SPEEDDUPLEX but there are noe selections for force 1 Gb. Only for speeds lower than 1 Gb (like 100MB and 10MB). Is there any other way we can turn this off completely (permanently)?
Caguicla_Intel
Hello DUrfj, Thank you for posting in Intel Ethernet Communities. Can you share the model of the Ethernet adapter used on your system as well as the Operating System? We look forward to your response. Let me know if you have additional questions. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
DUrfj
I have connected a Tews 888 fiber module. Daniel
DUrfj
Operating system is windows 7. Daniel
Caguicla_Intel
Hello Daniel, Thank you for the prompt reply. We have found that your query will be best answered by our Embedded Support team, we will help you to move this post to the designated team. Please feel free to contact us if you need assistance form Ethernet support team. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
CarlosAM_INTEL
​Hello, @DUrfj​:
In order to be on the same page, could you please let us know if the affected design has been developed by you or by a third-party manufacturer? In case that it is a third-party device , please give the model, part number , and where is stated its documentation.
Waiting for your answer.
@Mæcenas_INTEL​.
DUrfj
We have a Kontron server blade and added the Tews (tcmc-888) fiber card. We got the card recommended for our suppiler. Datasheet: http://www.tews.com/PressNews/Datasheet_20TXMC888,property=Original.pdf Daniel
CarlosAM_INTEL
​Hello, @DUrfj​:
Thanks for your clarification.
We would like to help you, but the proper information to answer question should be requested to the channels listed as a reference at the following website:
http://www.tews.com/Navigation/Internet/support-button,templateId=fs-topic.jsp,mid=1756,sid=1768.html
@Mæcenas_INTEL​.
DUrfj
Tews sayd that your tool Lanconf shoulde be used. D
CarlosAM_INTEL
​Hello, @DUrfj​:
Thanks for your update.
You should verify with the manufacturer of the third-party design related to this thread if the information stated in section 6.2.7, on pages 191 and 192 of the Intel (R) Ethernet I210 Datasheet document # 333016 Is the proper to answer your questions. The cited document can be found at:
https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/i210-ethernet-controller-datasheet.pdf
@Mæcenas_INTEL​.
