Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
915 Discussions
The feasibility of dropping the duplicated receiving packets within a specified guard time period on
CharlieChenEC
I have a special requirement against the received packets on the switching ASIC and would like to know the feasibility to support this on Tofino or Tofino2 at SOC level.
Given that the guard time period is 10 msec. The payload of the packets mentioned below are all the same.
1. Packet 1 is received on the switching ASIC from any port at timestamp 0 msec. The packet is processed by the ASIC as usual.
2. Packet 2 is received on the switching ASIC from any port at timestamp 1 msec. The packet is dropped.
3. Packet 3 is received on the switching ASIC from any port at timestamp 10 msec. The packet is dropped.
4. Packet 4 is received on the switching ASIC from any port at timestamp 12 msec. The packet is processed by the ASIC as usual.
5. Packet 5 is received on the switching ASIC from any port at timestamp 17 msec. The packet is dropped.
6. Packet 6 is received on the switching ASIC from any port at timestamp 23 msec. The packet is processed by the ASIC as usual.
Is there any existing API of Intel P4 SDE available to do that without the intervention of CPU?
Or is it possible to use P4 lang on Tofino or Tofino2 to do that without the intervention of CPU?
Mike_Intel
Hello CharlieChenEC,
For us to further check the issue, please provide the following details.
  1. What is the complete model of the Ethernet card that you are using?
  2. Are you designing board or a system using the Ethernet card?
  3. Can you provide more information about the implementation of the network card?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
CharlieChenEC
Hi Michael,
    We would like to know the feasibility to do the feature on the models listed below. All of them are Ethernet Switches.
    Wedge100BF-32X (Tofino)
    Wedge100BF-65X (Tofino)
    AS9516-32D (Tofino2)
    No. We would like to develop the feature on the models mentioned above.
    We would like to develop the feature on the Ethernet Switches with Tofino/Tofino2 switching ASICs.
Thanks and best regards,
Charlie Chen
Mike_Intel
Thank you for the quick reply. Since your issue is regarding our Programmable Ethernet Switches Products, we need to route this thread to the correct group so you will be better assisted by the proper team.
Please wait for their reply within 1 to 2 business days.
Thank you and stay safe.
Michael L.
Adolfo_S_Intel
Hello, @CharlieChenEC ,
We will provide more information about your inquiry as soon as posible.
BR,
@Adolfo_S_Intel
CharlieChenEC
Hi Adolfo,
Thanks for your help. I'm looking forward to see your comment.
Charlie Chen
CharlieChenEC
Hi Adolfo,
Is there any update on this question?
