Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
930 Discussions
What is the appropriate flash load file to use on the I210 in order to get a 10/100 Base-T interface.
MScha13
VincentT_Intel
Hi MScha13, Thank you for posting in Intel® Ethernet Community. Your query is best to be addressed by our Embedded Products forum, I'll be moving your thread for faster response. Best Regards, Vince T. Intel Customer Support Under Contract to Intel Corporation
CarlosAM_INTEL
​Hello, @MScha13​:
The External SGMII device configuration supports the cited interface. You can confirm this information and more details in section 3.7.1 on page 87 of the Intel(R) Ethernet Controller I210 Datasheet document # 333016. It can be found at
https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/i210-ethernet-controller-datasheet.pdf
Due to this fact, we suggest you use the image related to the cited configuration.
We hope that this information may help you.
@Mæcenas_INTEL​.
