Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
913 Discussions
Window can not recongnize WGI210IT on my custom board
cafe820
My custom design board has two WGI210IT on board with ATOM off-the-shelf module.
Each WGI210IT has blank external flash which never be programmed.
This board is in bring-up stage.
Two WGI210IT can be seen in window "device manager" as "unknown device".
Following shows device property and message as "no driver installed (code 28)
I guess they need to be programmed with something.
My questions are :
1. What's the reason of this case
2. Should I program iNVM/external flash?
3. If yes, which tool can I use and where can I get it?
Sihyoung
Caguicla_Intel
Hello Sihyoung,
After checking, we found a similar inquiry from you on our database and noticed that there is no response. With this, we'd like to check if you still need our assistance on this matter. If yes, kindly provide the following information that would help us in checking your request.
1.) When you mentioned custom board, can you confirm if this is your own designed board?
2.) Is this a newly built board/system?
Should there be no response, I’ll make sure to reach out after 3 business days.
Crisselle C
Intel® Customer Support
cafe820
Hello Crisselle,
Thank you for reply in advance.
     Yes, it is own designed board and has two i210-it
    Yes, I think need to program iNVM
   The DEVID read 8086:1531. I guess it need to be changed to  8086:157b through iNVM programming
   But I couldn't get access RDC area to get app and templete.
My account can not be changed to Privileged EDC account.
Sihyoung
Caguicla_Intel
Hello Sihyoung,
Thank you for the reply.
Since this is your own designed board, we will help you to move this post to embedded connectivity topic. They are in best position where you can get an assistance.
If you have additional assistance needed from Intel Ethernet team, please do not hesitate to submit a new question.
May you have an amazing day ahead!
Crisselle C
CarlosAM_INTEL
Hello, @cafe820:
You can find the information that may answer your questions in the replies to consultations 2.14, 2.15, and 2.16, on page 8 of the Intel® Ethernet Controller I210/I211 Frequently Asked Questions (FAQs) document # 335346 at the following website:
https://cdrdv2.intel.com/v1/dl/getContent/334026
You can find the Intel® Ethernet Controller I210 and I211- AT Production NVM Images document # 513655 and Intel® Network Connections Tools 25.2 PV LAN Software Tools document # 348742 that has the EEUpdate tool, when you are logged into your Resource & Design Center (RDC) privileged account in the following websites:
https://cdrdv2.intel.com/v1/dl/getContent/513655
https://cdrdv2.intel.com/v1/dl/getContent/348742
The RDC Account Support form is the channel to process your account update request or any inconveniences with the provided websites. It can be found at:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
@CarlosAM_INTEL.
