I am trying to bring-up a design with X550-AT2 connected to PCIe PEG x4.
Unfortunately I was not able to get the device detected in EFI shell / BIOS or Operating system.
All supply voltages are present
PCI clock is present
Perst high
I found out, that the signals listed below do not have any pull-ups or pull-downs
NCSI_CLK_IN pull-down
NCSI_CRS_DV pull-down
NCSI_RXD1 pull-up
NCSI_RXD0 pull-up
NCSI_TX_EN pull-down
NCSI_TXD1 pull-down
NCSI_TXD0 pull-down
Can this cause the PCIe Interface not to work?
Is there a workaround to get the PCIe interface to work? Probably through JTAG access?
Many Thanks
Best Regards
Andreas
Hello lu_he_de,
.Base on your inquiry, we have specific forum for these issues and I will be transferring this thread for faster response.
Please wait for their reply within 1 to 2 business days.
Thank you and stay safe.
Michael L.
Intel® Customer Support
Hi Michael,
thank you very much!
Best Regards
Andreas
Hi Andreas,
Thank you for contacting the Intel Embedded Community.
Usually PEG ports only works as PCIe x1 when you connect a Non-Graphics device (X550-AT2); so not sure which board you are using, but please check this first with your motherboard manufacturer or use a different PCIe port.
Jaime L.
Hi Jaime,
thank you for lookingt into my issue.
I am in touch with the manufacturer of the COM module I am using. We have developed ourselves the COM Carrier board. The COM module`s manufacturer has tested the PEG with another Ethernet module. I will try to set up another test with the COM reference carrier.
In the COM module`s hardware manual it is written, that the modules`PEG can be split into 1x8 and 2x4 what we did
Can you please tell me where to get the initial NVM firmware for X550 AT. I have found many update versions but the module`s manufacturer says I should install first x550-nvm-2-20-release.zip“ 605169-x550-nvm-2-00-release.zip
In the update packages there are many bin files. Which one is the right, to rule out that NVM firmware is not the issue?
Best Regards
Andreas
Hi Jaime,
I got the PCIe PEG part up and running. I face now issues with the second Ethernet Port and I don`t know which flash content I need to program. Can you please let me know?
Best Regards
Andreas
I have also found two power up sequence charts.
I got X550 detected on PCIe now. Running it with PEG is no issue. Also unconnected NCSI wires seem not to block PCIe
I programmed flash content to the Flash
I am till wondering which one is the appropriate file
So far I haven`t got any Ethernet Link, but the PCIe is up and running which is half of the cake
i got one port ETH0 up and running
unfortunately the second port does not work when i connect a cable
I have pulled both EN_Signals high and also together just for second debugging
Can you please give a hint?
Is this maybe related to the right flash content?
I am still not sure which content I need to program into NVM
Best Regards
Andreas
Hi Andreas,
Please below link for downloading the NVM utility for the X550 Ethernet adapter, just select the proper OS utility.
Jaime L.
Hello Jaime,
many thanks
I installed NVM utility and use it
A similar problem with one port inactive I found in this thread
I think the behaviour I experience is the same
Best Regards
Andreas
Hello Jaime,
I can still not get the second port active
What I can try to solve this?
Best Regards
Andreas
Hello Jaime,
thanks. I have already applied for Premier Support and asked at the distributor`s. I hope I will get the required information then.
Best Regards
Andreas
