- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Dear intel team,
i am designing a cutom board with the intel I225 Ethernet controller and have some questions about the intregrated magnetics RJ45 jack (ICM/MagJack).
- In the Reference Schematic Rev2.5, it says:
"Suggest to select Magnetics part with common mode chokes on the Cable side."
However, I am struggling to find any part with this configuration.
In the Design Considerations and Guidelines document, it says:
"Remove Magnetics Common-Mode Chokes locations requirement."
So, is it really necessary to have the magnetics on the cable side or not? - I consider using the part no. 0826-1X4T-HT-F without using the PoE functionality, i.e. leave the PoE pins unconnected. Could you tell me if this part is appropriate for use with the intel I225 ? Or can you recommend a different 1X4-port part ?
Thanks in advance for your help.
Marcel
Link kopiert
3 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello, @mmg
I have sent you some information that might be useful for your case to your e-mail.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Is there a way to get that information as well? I also want to use a MagJack with Common-Mode Chokes on the chip side.
BTW: 607353 refers to "Intel® 2.5G BASE-T Magnetic Specification Electrical/Mechanical Requirements for 2.5G BASE-T Magnetic Components" but that Document can't be found anywhere.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
nevermind.... I just downloaded the newest Ref.-Design-Files. The hint about the position CMC is changed now.
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
