Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
X550-AT2 bring-up
lu_he_de
I am trying to bring-up a design with X550-AT2 connected to PCIe PEG x4.
Unfortunately I was not able to get the device detected in EFI shell / BIOS or Operating system.
All supply voltages are present
PCI clock is present
Perst high
I found out, that the signals listed below do not have any pull-ups or pull-downs
NCSI_CLK_IN                     pull-down
NCSI_CRS_DV                   pull-down
NCSI_RXD1                        pull-up
NCSI_RXD0                        pull-up
NCSI_TX_EN                      pull-down
NCSI_TXD1                         pull-down
NCSI_TXD0                         pull-down
Can this cause the PCIe Interface not to work?
Is there a workaround to get the PCIe interface to work? Probably through JTAG access?
Many Thanks
Best Regards
Andreas
Mike_Intel
Hello lu_he_de,
.Base on your inquiry, we have specific forum for these issues and I will be transferring this thread for faster response.
Please wait for their reply within 1 to 2 business days.
Thank you and stay safe.
Michael L.
Intel® Customer Support
lu_he_de
Hi Michael,
thank you very much!
Best Regards
Andreas
Jaime_Lizarme
Hi Andreas,
Thank you for contacting the Intel Embedded Community.
Usually PEG ports only works as PCIe x1 when you connect a Non-Graphics device (X550-AT2); so not sure which board you are using, but please check this first with your motherboard manufacturer or use a different PCIe port.
Jaime L.
lu_he_de
Hi Jaime,
thank you for lookingt into my issue.
I am in touch with the manufacturer of the COM module I am using. We have developed ourselves the COM Carrier board. The COM module`s manufacturer has tested the PEG with another Ethernet module. I will try to set up another test with the COM reference carrier.
In the COM module`s hardware manual it is written, that the modules`PEG can be split into 1x8 and 2x4 what we did
Can you please tell me where to get the initial NVM firmware for X550 AT. I have found many update versions but the module`s manufacturer says I should install first x550-nvm-2-20-release.zip“ 605169-x550-nvm-2-00-release.zip
In the update packages there are many bin files. Which one is the right, to rule out that NVM firmware is not the issue?
Best Regards
Andreas
lu_he_de
Hi Jaime,
I got the PCIe PEG part up and running. I face now issues with the second Ethernet Port and I don`t know which flash content I need to program. Can you please let me know?
Best Regards
Andreas
lu_he_de
I have also found two power up sequence charts.
lu_he_de
I got X550 detected on PCIe now. Running it with PEG is no issue. Also unconnected NCSI wires seem not to block PCIe
I programmed flash content to the Flash
I am till wondering which one is the appropriate file
So far I haven`t got any Ethernet Link, but the PCIe is up and running which is half of the cake
lu_he_de
i got one port ETH0 up and running
unfortunately the second port does not work when i connect a cable
I have pulled both EN_Signals high and also together just for second debugging
Can you please give a hint?
Is this maybe related to the right flash content?
I am still not sure which content I need to program into NVM
Best Regards
Andreas
Jaime_Lizarme
Hi Andreas,
Please below link for downloading the NVM utility for the X550 Ethernet adapter, just select the proper OS utility.
https://www.intel.com/content/www/us/en/search.html?ws=text#sort=relevancy&layout=table&f:@emtcontenttype_en=[Firmware]&f:@tabfilter=[Downloads]&f:@stm_10385_en=[Ethernet%20Products,500%20Series%20Controllers%20(up%20to%2010GbE),Intel%C2%AE%20Ethernet%20Controller%20X550]
Jaime L.
lu_he_de
Hello Jaime,
many thanks
I installed NVM utility and use it
A similar problem with one port inactive I found in this thread
https://community.intel.com/t5/Embedded-Connectivity/X550-AT2-2nd-MDI-Port-visible-but-not-active/m-p/1316688#M3392
I think the behaviour I experience is the same
Best Regards
Andreas
lu_he_de
Hello Jaime,
I can still not get the second port active
https://community.intel.com/t5/Embedded-Connectivity/X550-AT2-2nd-MDI-Port-visible-but-not-active/m-...
What I can try to solve this?
Best Regards
Andreas
lu_he_de
Hello Jaime,
thanks. I have already applied for Premier Support and asked at the distributor`s. I hope I will get the required information then.
Best Regards
Andreas
