Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
X710 RSS hash algorithm
JINLI
Does it support hashing a TCP session into the same queue by default when X710 NIC enabled RSS multi-queue? Or how can I config it?
AndrewG_Intel
Hello JINLI
We noticed that your inquiry is regarding Intel® Ethernet Adapter X710 Series. We have a forum for those specific products and questions so we are moving it to that the Ethernet Products Forum so it can get answered more quickly: https://community.intel.com/t5/Ethernet-Products/bd-p/ethernet-products
Andrew G.
Mike_Intel
Hello JINLI,
Before we proceed, I need to clarify if you are designing a system with embedded X710?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel Customer Support Technicians
JINLI
Dear Michael L.
    Thank you for your reply.
    We are now designing a system. However, we are not very clear which kind of NIC to choose. We have a demand that needs to hash a TCP session to one queue when we use RSS on NIC. So, we want to know if X710 meets this demand. If so, we can choose this kind of NIC.
Mike_Intel
Hello JINLI,
Base on your inquiry, we have specific forum for these issues and I will be transferring this thread for faster response.
Michael L.
CarlosAM_INTEL
Hello, @JINLI:
You can find the information that may answer your questions associated with the Intel® Ethernet Controller X710- TM4/AT2 in sections 7.1.8, 7.1.10.1.2, 7.4.5.2.3, 8.3.2.2.1, and Tables 4-1, 7-74, 7-129, 7-134, 7-211, and 8-3; on pages 589, 590, 596, 679, 969, 971, 198, 738, 787, 792, 917,  and 964 of   Intel® Ethernet Controller X710-TM4/AT2 Datasheet document # 596333. You can find this document when you are logged into your Resource and Design Center (RDC) privileged account on the following website:
https://cdrdv2.intel.com/v1/dl/getContent/596333
You should fill out the form stated on the following website when you have problems with the provided website or want to update your RDC account:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
@CarlosAM_INTEL.
