Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
XL710 Device ID differences
ML-WR
How can I find the programming differences between XL710 devices with different Device IDs.
What are programming differences between XL710.1583 and XL710.1581?
Diego_INTEL
Hello @ML-WR,
You can check in the datasheet all the information regarding the controller, you can check document #332464 - Intel® Ethernet Controller X710/XXV710/XL710 Datasheet.
https://cdrdv2.intel.com/v1/dl/getContent/332464
Section 6.3.21.7 PF LAN device ID (0x0007)
@Diego_INTEL
