Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
941 Discussions
bldk & Intel SCH message Network
Hello.
I'm tring to read PMA base haddress in order to throttle the cpu clock (Z510 / U15W) by bios.
Reference data sheet is :
Intel® System Controller Hub
(Intel® SCH)
External Design Specification (EDS)
May 2010
Revision 2.21
To issue the read on Intel Sch Message Network I'm doing:
// Intel SCH Message Network (offset 0x70 port 4)
// opcode = 0xD0 (read)
// target port = 0x04
// Reg. Address = 0x70
// Byte Enable = 0x00
pciwrite32(0, 0, 0, 0xd4, 0x00000000); // Set MDR = 0
pciwrite32(0, 0, 0, 0xd0, 0xd0047000); // Issue Read command MCR
delay(100);
data32 = pciread32(0, 0, 0, 0xd4);
sprintf(buffer, "HOST BRIDGE PMBA = 0x%08X\n\r", data32);
writeString(buffer);
RepeatUntilKeyPressed();
The return code is always 0x4 (data32) what's wrong?
Best Regards
FMcNu1
Valued Contributor I
Wecome to the Intel® Embedded Community.
I want to make you aware of a special place to go with questions like yours. The Intel® e-Help desk is staffed by Intel representatives who support select Intel embedded platforms including Intel Atom™ and SCH.
To access e-Help, you need to be a Privileged member of the Intel® Embedded Community.
If you are not already a Privileged member, you can request an upgrade to your community account here:
https://edc.intel.com/My-Account.aspx https://edc.intel.com/My-Account.aspx
In addition to access to e-Help, Prvileged members may also access the confidential content within the Intel® Embedded Design Center, such as design documents, specifications, and training materials.
I hope this helps.
Felix
J. Felix McNulty
Community Moderator (Intel contractor)
