Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
i210 iNVM limit
yousuke
Is there a limit to the number of times the i210 can be written to iNVM?
Diego_INTEL
Hello @yousuke,
Yes, there is a limited number. You can check section 3.4 from the i210 datasheet.
"iNVM is similar to One Time Programmable (OTP) memory except that it allows for a limited number of modifications and corrections after initial programming."
@Diego_INTEL
Diego_INTEL
Hello @yousuke,
@Diego_INTEL
BrianLPR
Is there a way to blank/erase the iNVM to start from square one?
CarlosAM_INTEL
Hello, @BrianLPR:
The information that may help you is stated in the answers to questions 2.14, 2.15, 2.16, 2.23, and 2.25, on pages 8 and 9 of the document stated in the following website:
https://cdrdv2-public.intel.com/334026/ethernet-controller-i210-i211-faq.pdf
@CarlosAM_INTEL.
