Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
Can I226 support Ethercat?
Dylan6
Please help to check if I226 can support Ethercat protocol or not. If not, can we use I225 to replace it? Because we can not find I226 in the supported list from Beckoff website? https://infosys.beckhoff.com/english.php?content=../content/1033/tc3_overview/9309844363.html&id=
CarlosAM_INTEL
Hello, @Dylan6:
You should consider that the differences between the cited Ethernet Controllers can be found on page 3 of the document stated in the following website:
https://www.intel.com/content/www/us/en/content-details/621753/intel-ethernet-controller-i225-i226-product-brief.html
This information should be verified by the company listed in your previous communication to confirm the compatibility of the Intel® Ethernet Controller I226 with EtherCAT protocol. You should use as a reference the form stated in the following website to contact the mentioned company:
https://www.beckhoff.com/en-en/support/support-form/index.aspx
@CarlosAM_INTEL.
