Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
923 Discussions
i210 voltage levels on SGMII interface
FCham
Hi everyone,
we are using a i210IS connected to an FPGA through its SGMII/MDIO interface.
MDIO works fine, but I can't find any information concerning the electrical levels required on the SER_P and SER_N pins, or out of the SET_P and SET_N pins.
Is that information available somewhere?
Thanks!
CarlosAM_INTEL
Hello, FCh:
In order to be on the same page, could you please tell us if the requested information is needed to find a solution for a technical problem? In case that your answer is affirmative, please give us a detailed description of the issue.
Waiting for your reply.
Carlos_A.
