Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
i210
MStre5
we programmed the i210 iNVM with the "i210_Invm_SerdDesKX_NoAPM_v0.6.txt"
Therfore we got the ID 157C we expected the ID 1536. What is the difference?
We don't find any tool to program the MAC-adress.
Can you help us?
CarlosAM_INTEL
Hello, M.Str :
In order to help you with device ID consultation, please review the answer to the question 2.13 on page 7 of the https://www.intel.com/content/dam/www/public/us/en/documents/faqs/ethernet-controller-i210-i211-faq.pdf Intel(R) Ethernet Controller I210/I211 Frequently Asked Questions (FAQs) document # 335346.
On the other hand, the EEupdate and LANConf may help you to program MAC addresses. These tools are included in the https://cdrd.intel.com/v1/dl/getcontent/348742 Intel(R) Network Connections Tools document # 348742.
These tools can be downloaded when you are logged in to your Embedded Design Center (EDC) privileged account.
We hope that this information may help you.
Carlos_A.
MStre5
with the tool "lanconf64.efi", i can program the i210-iNVM.
This is a GUI-tool.
Now i have the problem to program the iNVM in our production with a EFi-CommandLine-Tool.
Can you tell me, what tool I should use to program the iNVM?
I think eeupdate is not able to program the iNVM
Mit freundlichen Grüßen
Martin Streicher
CarlosAM_INTEL
Hello, M.Str :
Thanks for your update.
The information stated in the answer to the question 2.15, on page 8 of the https://www.intel.com/content/dam/www/public/us/en/documents/faqs/ethernet-controller-i210-i211-faq.pdf Intel(R) Ethernet Controller I210/I211 FAQs document # 335346, which should help you with your previous consultations.
Carlos_A .
MStre5
which option should we use to program the iNVM with eeupdate?
I couldn't find any.
best regard
martin streicher
CarlosAM_INTEL
Hello, M.Str:
Thanks for your reply.
Please refer to the DOCS file included in the Intel Network Connections Tools document # 348742, specifically the Intel(R) EEUpdate Release Notes (eeupdate.txt file) document, where is stated the information that may help you.
Carlos_A.
MStre5
now we have only the iNVM, the external Flash is not present.
we programed the file "I210_Invm_SerDesKX_NoAPM_v0.6.txt" and the MAC-Adress with "lanconf64e.efi" to the i210.
now the deviceID is 8086-157C
with linux "lspci" we see "Ethernet Controller: Intel Corporation I210 Gigabit Backplane Connection (rev 3)"
with the tool "diags64e.efi", we can see the MAC-adress. When we use the same tool second, the MAC-adress is "00 00 00 00 00 00"
What is wrong?
best regard
martin streicher
CarlosAM_INTEL
Hello, M.Str :
In order to be on the same page, could you please tell us if the design has been developed by you or a third party company? In case that it is a third party design, could you please give us all the information related to it? If it has been developed by you, could you please let us know if it has been reviewed by Intel? By the way, could you please inform us know how many units have been manufactured? How many are failing? What is the failure rate? Also, could you please clarify us if you have made any modification to your design and let us know them in a detailed way?
Waiting for your reply with the information that should answer these questions.
Carlos_A.
MStre5
it's our design (see i210.pdf) with removed R190,R498,R501,R502.
It is not reviewed by Intel.
The problem is with our first prototypes
best regards
martin streicher
CarlosAM_INTEL
Hello, M.Str :
In order to make a full verification of your implementation, please follow the steps stated in the https://edc.intel.com/Tools/Design-Review/Default.aspx?language=en Design Review Services website.
Carlos_A.
MStre5
we found the problem that we can only read the MAC-adress when we first start the diagnostic programm.
It was configured, that the iNVM data in not updated at SW-reset.
After that change the controller works.
MStre5
Hello Carlos,
we can progrm the iNVM with the tool eeupdate. This is ok.
Is it only possible to program the MAC in the iNVM with eeupdate /MAC=?
Or how can we put many MAC-adresses in a file and program the MAC-adress with this file?
Best regard Martin
CarlosAM_INTEL
Hello, M.Str:
Thanks for your updates.
In order to help you, we will contact you via email.
Carlos_A.
