Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
i226 databook
FintanBuckley
We are implementing a vision system with the i226 and will be supporting PTP. Where can we get the databook for the i226.
Fintan
Jaime_Lizarme
Hello Fintan,
The i226 is the same for i225, so you need to be logged into your Resource & Design Center (RDC) privileged account to find the Intel(R) Ethernet Controller I225 Datasheet Document # 596659 on the following websites:
http://www.intel.com/cd/edesign/library/asmo-na/eng/596659.htm
The RDC Account Support form is the channel to process your update account or report any problems with the provided site. You should fill it out on the following website:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
Jaime L.
FintanBuckley
Unfortunately, the data sheet does not have all of the information that we require. We are planning to use
the i226 with a non-standard OS in an embedded environment. Is there someone we can discuss our particular
issues with?
Fintan
