Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
943 Discussions
iqvw64e.sys blocked tried other suggestions - problem persists
Fred_T
Since my last Windows 11 update 24H2, every time I boot up I get the error that a security setting is blocking iqvw64e.sys. I have a Dell XPS 8940.  All the Dell upates including the Support Assist have been applies. All the Intel updates have been done. except Killer Performance Suite installation failed with error code 1603. I have turned off Memory Integrity.  I have searched my system for the iqvw64e.sys file and can't find it.  I've even searched specifically in Windows32 and its driver folder.  Can't find the file.
HELP
Diego_INTEL
Hello @Fred_T,
I have found this link with a similar issue that you are having.
https://www.reddit.com/r/sysadmin/comments/xx3oya/22h2_vulnerable_intel_nic_driver_iqvw64esys/?rdt=38589
"This was corrected by simply uninstalling the Intel network connections software entirely."
@Diego_INTEL
Fred_T
Thanks for trying to help.  But I couldn't find anything similar to uninstall.  Or any solution in the article.
