Hi Intel,
I'm using the eepromaccesstool (v0.8.0) to flash mac address on arm64 Orin NX platform.
I can get the i210 device. But when I dump and flash, I got following error.
Enable Serial Flash Bit Interface timed out.
eepromaccesstool-0.8.0$ sudo ./EepromAccessTool
Intel(R) EEPROM Access Tool NVM/OTP Programming Example Tool Version 0.8.0
Provided under the terms of a CNDA. Do Not Distribute.
Copyright(C) 2017-2020 by Intel(R) Corporation
NIC BUS DEV FUN Silicon Memory Type Present
1 1 0 0 I210 INVM+FLASH
eepromaccesstool-0.8.0$ sudo ./EepromAccessTool -nic=1 -dump
Using FW mode
Found an NVM
^C
eepromaccesstool-0.8.0$ sudo ./EepromAccessTool -NIC=1 -f=I2104XNB.bin
Using FW mode
size is 80000
Detected FlashId: ffff
Using generic method
Erasing Full NVM...
^CPlease help us.
Hello @WilsonASRI ,
We sent an email to the address associated with this account with information that may help you.
Jaime L.
Hi:
Are you successful now? I have the same problem. I also use i210 on the Jetson Orin platform, but the flash always fails
