Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
907 Discussions
eepromaccesstool for I210 on arm64 Orin NX platform
WilsonASRI
Hi Intel,
I'm using the eepromaccesstool (v0.8.0) to flash mac address on arm64 Orin NX platform.
I can get the i210 device. But when I dump and flash, I got following error.
Enable Serial Flash Bit Interface timed out.
eepromaccesstool-0.8.0$ sudo ./EepromAccessTool
Intel(R) EEPROM Access Tool NVM/OTP Programming Example Tool   Version 0.8.0
Provided under the terms of a CNDA.  Do Not Distribute.
Copyright(C) 2017-2020 by Intel(R) Corporation
NIC	BUS	DEV	FUN	Silicon	Memory Type Present
 1	1	 0	 0	I210	     INVM+FLASH
eepromaccesstool-0.8.0$ sudo ./EepromAccessTool -nic=1 -dump
Using FW mode
Found an NVM
^C
eepromaccesstool-0.8.0$ sudo ./EepromAccessTool -NIC=1 -f=I2104XNB.bin
Using FW mode
size is 80000
Detected FlashId: ffff
Using generic method
Erasing Full NVM...
^C
Please help us.
Jaime_Lizarme
Hello @WilsonASRI ,
We sent an email to the address associated with this account with information that may help you.
Jaime L.
yanhy
Hi:
Are you successful now? I have the same problem. I also use i210 on the Jetson Orin platform, but the flash always fails
