Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
956 Discussions
setup ethernet i225-it driver error on CentOS 8, With kernel Ver 4.18.0-348
yang_cheng_yu
Hi:
I  have a  computer with  3  intel ethernet interface  , The  model  is i225-it.   Linux version is         'CentOS 8   4.18.0.348.el8.x86_64
1 、I  have got  igc driver files  from  https://mirrors.edge.kernel.org/pub/linux/kernel/v5.x/5.8.7
2、  i  compile  the driver under  dir  inux-5.8.7/drivers/net/ethernet/intel/igc  successfully。
2、  type:  insmod  igc.ko
3、 check status:   dmesg | grep igc  ,  shows  bellow error message:
      igc:probe of 0000:02:00.0 failed with error -2
       igc:probe of 0000:03:00.0 failed with error -2
       igc:probe of 0000:05:00.0 failed with error -2
4、 the makefile context bellow:
obj-$(CONFIG_IGC) += igc.o
igc-objs := igc_main.o igc_mac.o igc_i225.o igc_base.o igc_nvm.o igc_phy.o \
igc_diag.o igc_ethtool.o igc_ptp.o igc_dump.o igc_tsn.o
KERNEL_SRC :=/lib/modules/$(shell uname -r)/build
all:
$(MAKE) -C $(KERNEL_SRC) M=$(PWD) modules
clean:
$(MAKE) -C $(KERNEL_SRC) M=$(PWD) clean
.PHONY: clean  all
       Thanks!
