1249 Discussions
About PCS register of TSN GbE Controller of Atom x6000E series
AN889
TSN GbE Controller of Atom x6000E series has PCS register. However, the datasheet (doc# 636723) does not describe the detail of PCS register. I want to know bit fields definition of PCS register.
CarlosAM_INTEL
Hello, @AN889:
We have received your request, but we want to address the following questions:
Please let us know if your request is related to technical problems, please give us a detailed description of the issues if your answer is yes.
What are the part numbers of the processors related to your requests? What is the name of the company that sold you the processors?
We are waiting for your answer.
@CarlosAM_INTEL.
AN889
Hello CarlosAM_INTEL,
Thank you for your answer.
I use the controller with fixed speed (auto negotiation disabled). However, it does not work. So, I investigate the linux driver shown as below:
https://github.com/intel/linux-intel-lts/tree/5.15/linux/drivers/net/ethernet/stmicro/stmmac
The linux driver defines PCS register as the follow:
https://github.com/intel/linux-intel-lts/blob/5.15/linux/drivers/net/ethernet/stmicro/stmmac/stmmac_pcs.h
I want to know if it is correct.
I am an end user. So, I don't know the above information.
AN889
CarlosAM_INTEL
Hello,  @AN889:
Thanks for your reply.
We need to address the following question to clarify the received information:
Based on your previous reply, could you please inform the part numbers, models, and name of the company that made the devices related to your request?
We are waiting for your clarification.
@CarlosAM_INTEL.
AN889
Thank you for your reply.
part number: I don't know.
models: Atom x6425E
company: Schneider Electric
AN889
CarlosAM_INTEL
Hello, @AN889:
We suggest using the channels listed on the following website as a reference to receive the proper support with your third-party device:
https://www.se.com/us/en/work/support/myschneider-app/connect-to-us.jsp
@CarlosAM_INTEL.
