1236 Discussions
Amston Lake (7433) dynamic graphics memory
Ludwigs
What is the maximum size of DRAM which can be used by graphics processor?
DhannielM_Intel
Hello Ludwigs,
Thank you for posting in the community!
To ensure you receive the most specialized assistance, we have a dedicated forum that addresses these specific concerns. Therefore, I will be moving this discussion to our Embedded Intel Atom® Processors Forum. This will allow our knowledgeable community and experts to provide you with timely and accurate solutions.
Dhanniel M.
Diego_INTEL
Hello @Ludwigs,
As I understand, usually the amount of memory that can be used by the integrated graphics is related to half of the maximum memory available in the system, checking in Intel Ark, the max memory size supported for the x7433RE is 32 GB, so, we can assume that the maximum memory for the graphics will be around 16 GB.
https://www.intel.com/content/www/us/en/products/sku/236967/intel-atom-x7433re-processor-6m-cache-up-to-3-40-ghz/specifications.html
By the way, if you would like to check what is the maximum VRAM allocated in your actual system using Windows, one fast way can be to run the dxdiag command in the Command Prompt and check the Display tab.
https://www.intel.com/content/www/us/en/support/articles/000041253/graphics.html
@Diego_INTEL
