Our product used the atom E3950 processor. We are now doing the PCB routing of the DDR circuit. We couldn't find the pin delay info file, which is needed to be input into Cadence PCB designer. We will also need to do simulation for signal integrity purpose after the layout is done. So, we will need the IBIS model file for the DDR controller of the E3950. Our simulation software is Hyperlynx. Could you help provide the pin delay info file and DDR4 related IBIS model.
G. F.
Hi @GFeng ,
Thank you for contacting the Intel Embedded Community.
In oder to get the information you need, an RDC account would be required; so, to get access to this you need to have a Resource and Design Center (RDC) privileged account.
The RDC Account Support form is the channel to process your account update process by filling out the form stated on the following website:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
You should use a business email address to evade any inconvenience. Please avoid the free email provider's address (such as the provided by Hotmail, Gmail, Yahoo, or others).
連結已複製
Hi @GFeng ,
I had already got a Developer Zone Premier Account by following the Intel customer support's instructions yesterday. I think that's the new name for the RDC privileged account. Please provide the reqested info file and IBIS models.
I already got the RDC privileged account. Could you help provide the download link for required files?
G. Feng
I think I found the package delay info. Because I am searching for the solution for LPDDR4, I didn't found the TLC sheet for LPDDR4 memory. However, there are TLC sheets for LPDDR3 (562062) and DDR3L(570342). Both of them contains the package length for each ball. So, I think I can use these info for LPDDR4, Is that correct?
G. Feng
