1266 Discussions
BLDK reference implementation for Crown Bay
sraou
I need to know about he BLDK reference implementation for Crown Bay that provided as default settings of BLDK. Will this implementation work on Atom "E660T", without modification?? I need an industrial processor.
FMcNu1
Valued Contributor I
Hello and welcome to the Intel® Embedded Community.
The only difference between the E660 (commercial SKU) and the E660T (extended temperature / industrial SKU) is the operating temperature spec. This is transparent to the software.
Felix
J. Felix McNulty
Community Moderator (Intel contractor)
sraou
Thanks Felix,
Now, I have a problem with products stepping. Will that implementation(BLDK reference) work on any stepping level of E660 and EG20T??
Thanks a lot for your attention.
Somayeh
FMcNu1
Somayeh,
The BLDK hardware dependencies should be documented in the BLDK Release Notes which you can find on the Intel® Embedded Design Center (EDC). For example, the following doc:
http://edc.intel.com/Link.aspx?id=3652 http://edc.intel.com/Link.aspx?id=3652
You will note that this particular doc and many others in the EDC are "locked" and available only to Community members with Privileged account status.
If you are not already a Privileged member, you can request an upgrade to your community account here:
https://edc.intel.com/My-Account.aspx https://edc.intel.com/My-Account.aspx
As a Privileged member, you may also access Intel® e-Help, which is staffed by dedicated Intel technical support people focused on embedded platforms.
I hope this helps.
Felix
J. Felix McNulty
