1232 Discussions
Monitor detection in EGMD 1.8 for win7 fail
LTurc
Hello
config:
E600 : 1Ghz, 1 Gb ram
Video port: DVI, with chrontel CH7307
We have an application where we boot our units without monitor.
Then we may connect a monitor.
With the Windows 7 Driver, the monitor is not detected and the display remain black
If we do a mouse right click on the desktop, the display turn on
In WinXp, all works well
If we use the WinXP driver on Windows 7 it also works.
and we use the same parameters to generate WinXP and Win7 Drivers
Note: in IEGD.INF from winxp driver package, there is a config line
HKR, ALL\1\General , DisplayDetect, %REG_DWORD%, 1
and this line is not present in Windows 7 installation files
Is there a way to correct this problem for Windows 7 drivers ?
or is this a bug for Windows 7 drivers
Laurent Turcotte
Kirk_B_Intel
Well sometimes we do not always get to do what we want. The DisplayDetect feature does not exist in the Win7 specific version of the driver and is not planned to be added.
So you can either use the Win7 version and put up with this particular operational characteristic, or use the XP version of the driver on Win7 and NOT have that issue.
Hope this helps.
Kirk_B_Intel
What is the specific version of the EMGD driver used on the E6xx on Win7?
Have you tried installing the XP driver on Win7 (yes it should work in XPDM mode but you do not get Aero support).
Have you tried adding the option to the Win7 INF file? It may not be supported but it will not hurt anything if it is not.
Hope this helps.
LTurc
>> Version of EGMD ?
Version 1.8 for both WinXP or Windows 7
Yes i tried, and the problem is not present.
But the client want to use Windows 7 version
Yes, but it did not work !
I did a text search in the driver files but did not find the "DisplayDetect" string.
other value like "DisplayConfig" can be found.
WinXp drivers contains both keys in the driver files.
Kirk_B_Intel
Hope this helps.
LTurc
this is not the answer i was hoping for !
I would have thought that plugging a display in a netbook/laptop
and detecting it without rebooting the unit was a requirement for the video drivers.
regards
Laurent Turcotte
Kirk_B_Intel
It is all a mater of targeted use case for the source base for each solution. The XPDM EMGD code was purpose built for embedded that needed capabilities like leaving an output port alive even when there is no monitor. There is a LOT of configurability designed into the driver. The Win7 specific EMGD uses a different code base where the use case values the driver doing what it thinks is right rather than what the user may want to do so we gain ease of configuration at the loss of configurability. Personally I prefer the driver do what I want which is why I use the EMGD "for XP" on Win7 rather than the Win7 specific driver.
