Bay Trail Z37xx Max Resolution?
HTay
Hello and good day!
Is there a reference that states the maximum resolution for the GPU that comes with the Bay Trail Z37xx family? E.g. max res for LCD output (LVDS or DSI), max res for OpenGL rendering, max res for video decoding, etc.
I tried looking on Ark and the datasheet provided there but I couldn't find this info, pardon me.
Many thanks!
Hugh Tay
Casey_H_Intel
Hello Hugh,
A few points to consider. First, the Intel® Atom™ Processor Z3740 has been superseded by the Z3745. This part contains a newer stepping of the silicon. Second, we only support Windows* 8.1 and Android* KitKat on the parts you have specified. Therefore, I can provide you details for Android.
eDP 1.3 Max Single Resolution = 2560x1600x24 @ 60
HDMI 1.4a Max Single Resolution = 1080p @ 60
MIPI-DSI Max Single Resolution = 1920x1200x24 @ 60 (x4 lanes)
H.264 Decode = up to 4kx2kp30, 1080p120
VP8 Decode = 1080p30
JPEG Decode = 100 Mpps (4:2:0)
MPEG-4 Decode = 720p30 ASP, 480p30 SP
H.263 Decode = 480p30
Casey H.
Casey_H_Intel
Hello Hugh,
I am researching the answer to your question and will reply again shortly with more information.
Casey H.
Casey_H_Intel
Hello Hugh,
The answer depends upon the OS (Android vs. Windows), and also by processor SKU (Entry or Main). If you are able to be more specific to those points, I believe I will be able to locate the information for you.
Casey H.
HTay
Hi Casey,
Nice to meet you again! =)
The particular CPU's I'm interested in are Z3735D and Z3740. The OS will be Fedora GNU/Linux, but I suppose if specific info for this OS is not available, Android info works fine too.
Many thanks!
Hugh Tay
Casey_H_Intel
Hello Hugh,
Casey H.
HTay
Ah, thank you! This is extremely helpful. =)
