1267 Discussions
Disable Thermal Management atom e620T
KFrie2
Hallo together,
i would like to disable the thermal management of the atom e620T
The Thermal Management is supported through therminal monitor and therminal monitor 2 in the atom processor. We use a BLDK to configure registers.
I would like to disable the throttling of the cpu und disable the SpeeStep function.
Like i know the disabling of thes functions is possible.
I can disable thermal control circuit and tm2 in the 1A0 register.
When i disable this functions, are all thermal management functions disabled?
Or is there any thermal management like throttling running in the background, which i cant disable.
I dont want to throttle down the clock or speedstep the processor.
Best regards
Konstantin
CarlosAM_INTEL
Hello, SpaceMachine :
We suggest you follow the guidelines stated in section 13 of the https://cdrdv2.intel.com/v1/dl/getContent/433303 Intel Atom Processor E6xx Series External Design Specification (EDS) document # 433303.
This EDS is accessible when you are logged into your Resource & Design Center (RDC) privileged account. It can be requested by filling out the https://www.intel.com/content/www/us/en/forms/design/contact-support.html RDC Account Support form.
We hope that this information may help you.
Carlos_A.
