1225 Discussions
Do you have a notice or document in details which state "LPC 1.8V to 3.3V level shifter is needed for better stability instead of 1.8V only " for Intel Silvermont (Braswell)platform such as "Pentium® quad-core processor N3710"?
athan
We following Intel’s recommendation to use LPC 1.8V and implement LPC 1.8V to 3.3V level shifter for better stability of LPC 3.3V under embedded use conditions for our motherboard based on Intel® Pentium® quad-core processor N3710.
We would like to have more details about this changes affect, then we can convert customer to use latest modified LPC boards.
CarlosAM_INTEL
Hello, @athan​:
We suggest you verify the information stated in section 10, on pages 49 and 50 of the Intel(R) Low Pin Count [LPC] Interface Specification document # 251289 that can be found at:
https://www.intel.com/content/dam/www/program/design/us/en/documents/low-pin-count-interface-specification.pdf
The PCI Local Bus Specifications can be found as a reference at the following website:
https://pcisig.com/specifications/iov/
@Mæcenas_INTEL​.
