1249 Discussions
How do i activate the RHPROXY for windows 10 IOT at Intel ATOM E3930
DSten3
Hi There,
i trie to activate the RHPROX on my embedded device.
The OS i use is a Windows 10 IOT Enterprise with an Intel Atom E3930.
Thanks for your Help
CarlosAM_INTEL
Helllo, @DSten3​:
We suggest you as a reference review the information stated in the following website where you should address your consultations like the stated in your previous message:
https://social.msdn.microsoft.com/Forums/en-US/4a25ff63-b421-4a23-856f-acbfcfd93f83/support-for-resource-hub-proxy-rhproxy-driver-in-ltsb-branch?forum=WindowsIoT
@Mæcenas_INTEL​.
DSten3
Hello Maecenas
is was going thru all of the threads to this topic but can't find any information to my problem. I found out that the rhprxy has to be activated in the acpi table. But i could not find any information how i have to do this.
Where do i get the ACPI Table and how do i modfy it with the right information?
additional information about my system. I use windows 10 Iot Enterprise 1809. the RHProxy is activated under windows but isn't noticed by the ACPi Table
Best Regards
CarlosAM_INTEL
Hello, @DSten3​:
Thanks for your reply.
RHPROXY is a Microsoft framework, therefore you should refer to Microsoft sources of information like the one below:
https://docs.microsoft.com/en-us/windows/uwp/devices-sensors/enable-usermode-access
@Mæcenas_INTEL​.
