Embedded Intel Atom® Processors
Technological Conversations about Intel Atom® Hardware, Software, Firmware, Graphics
1222 Discussions
I have some questions about E3845's minimum DTS
JLee153
Débutant
2 789 Visites
Hello
I use E3845 (Baytrail-I) processor.
I had some temperature tests....
this test is Low temperature test...
The following measurement results were obtained.
After booting, DTS did not change for about 10 minutes.(38:08 ~ 48:09)...
temperature measure time after boot
temperature sensor adjacent to the CPU (ºC)
measured CPU temperature (ºC)
DTS value
Wed Nov 15 11:38:08.270 2017-35.50-9119 (0x77)Wed Nov 15 11:38:23.982 2017-34.50-9119 (0x77)Wed Nov 15 11:38:47.806 2017-33.50-9119 (0x77)Wed Nov 15 11:39:12.205 2017-32.50-9119 (0x77)Wed Nov 15 11:40:34.494 2017-30.00-9119 (0x77)Wed Nov 15 11:41:01.840 2017-29.00-9119 (0x77)Wed Nov 15 11:44:51.742 2017<td style...
0 Compliments
8 Réponses
CarlosAM_INTEL
Modérateur
1 803 Visites
Hello, JCLee:
The information that may help you is stated on page 4 of the https://www.intel.com/content/dam/www/public/us/en/documents/platform-briefs/atom-processor-e3800-platform-brief.pdf Intel(R) Atom(TM) Processor E3800 Product Family Platform Brief document # 329621.
We hope that this information may help you.
Carlos_A.
0 Compliments
JLee153
Débutant
1 803 Visites
Hello Carlos_A:
Thank you for your reply.
I know working temperature for E3845(Baytral-I) (-40 ~ 110)
So, I tested from -40 degrees.
Working is fine. but Read out temperature remain fixed for about 10 minutes.(-9 degrees).....
So, I want to knows minimum reportable temperature...
Please check the red underline below again.
So, What is the minimum reportable temperature for E3845 (BayTail-I) ?????????
JC
0 Compliments
JLee153
Débutant
1 803 Visites
Please check my logs....
0 Compliments
JLee153
Débutant
1 803 Visites
I refer to the following.
Attach documents and programs I have used.
0 Compliments
CarlosAM_INTEL
Modérateur
1 803 Visites
Hello, JCLee:
Thanks for your updates.
Based on your previous communications, could you please tell us if this request is related to a technical problem? In case that it is correct, could you please give us a detailed description of the issue?
Thanks again for your cooperation to solve this inconvenience.
Carlos_A.
0 Compliments
JLee153
Débutant
1 803 Visites
Hello Carlos_A:
I want to know if my test results are the minimum reporting temperature supported by Intel.
Are there any technical ways to read lower temperatures than the test results?
I could not find any way to set the DTS range or limit.
I would like to be offered technical ways to read lower temperatures than the test results.
If there is no way to read a lower temperatures than the test result,
is the test result value, -9 degrees, the minimum reportable temperature of the Intel E3845 (Baytrail-I)?
JCLee.
0 Compliments
JLee153
Débutant
1 803 Visites
The parts that can not be understood technically are as follows.
As shown below, the mask of "Readout" is 0x7F (bits 22:16).
0x7F has a value of 127.
Thus, DTS seems to be possible up to 127.
However, in the test result, the DTS value is output only to 119 (0x77).
I wonder why DTS from 120 (0x78) to 127 (0x7F) is not output.
0 Compliments
CarlosAM_INTEL
Modérateur
1 803 Visites
Hello, JCLee:
Thanks for your update.
We suggest you address this request by filling out the https://plan.seek.intel.com/us_en_embedded_registration-form-contactsaleswebform_html Contact Sales form.
Carlos_A.
0 Compliments
Répondre
