Embedded Intel Atom® Processors
Technological Conversations about Intel Atom® Hardware, Software, Firmware, Graphics
I need an IEGD for 865G
JWern1
초보자
4,269 조회수
I need the XP Intel Embedded Graphics Driver for 865G. Can anyone point me to it? The only IEGDs I currently find do not support this chipset. There used to be an 865 version downloadable on the Intel support website, but it doesn't appear to be available now. I need to be able to create configs with DTD information for various monitors.
Thanks for any help!
1 솔루션
JWern1
초보자
2,645 조회수
Good catch--I had overlooked that 855 was an option. Thank you very much AdolfoS! This works perfectly.
And thanks again to Kirk, LynnZ, and Gabriel. You are all fabulous. I had no doubt a group like that could steer me in the right direction.
원본 게시물의 솔루션 보기
0 포인트
9 응답
Gabriel_T_Intel
2,645 조회수
Hello Wern.
Welcome to the community. Have you checked into this set of drivers available for XP
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=865g Intel® Download Center .
Take a look into this link and please let us know you if you could find a driver suitable for your needs.
Best Regards.
Gabriel
0 포인트
JWern1
초보자
2,645 조회수
Thanks for the reply, Gabriel. I have checked into those drivers. Unfortunately, all have very limited support for monitor resolutions, specifically widescreen. There used to be a driver in the download center section for 865G called "Intel Embedded Graphics Driver (IEGD) with CED." This included a DTD editor allowing one to save monitor information to incorporate into the custom configuration. Unfortunately, the only IEGD ones I see currently do not have 865G as a configuration option.
0 포인트
Natalie_Z_Intel
2,645 조회수
Thanks for the reply, Jason! I checked within Intel, too, and official chipset support on IEGD went from 855 to 910 with no chipsets in between. The 865 might work with IEGD but that would be version 8.x of IEGD which Intel no longer supports and we checked the archives and 8.x does not exist. We have 10.x in the archives. LynnZ.
0 포인트
JWern1
초보자
2,645 조회수
I appreciate you checking into it, Lynn.
If anyone out there happens to have the old 865G "Intel Embedded Graphics Driver (IEGD) with CED," please contact me.
Alternatively, I know when Intel moved from that Extreme Graphics 2 chipset to GMA the setup information file (igxp32.inf for Windows XP) began having a section for including a list of custom DTDs. That's super-convenient, but it appears no such thing exists in the older line of drivers. If anyone knows a nifty trick like that, I'd love to hear from you.
Jason
0 포인트
Kirk_B_Intel
직원
2,645 조회수
I just googled "IEGD 8" and in the short list of hits I found the driver on one of those driver sites here:
http://intel.driversdown.com/Drivers.asp?ID=86293&brNum=3&show=0 Intel drivers download
(click the less obvious picture of the disk to download NOT any of the other download links)
Google is a wonderful thing- you should try it sometime!
Oddly enough, it takes you here: http://intel.driversdown.com/Download.asp?ID=86293&Url=http://downloadmirror.intel.com/13824/eng/IEGD_8_0_GOLD_1063.exe http://downloadmirror.intel.com/13824/eng/IEGD_8_0_GOLD_1063.exe
Apparently you are lucky and a file from 2007 is still on the server.
I downloaded and checked it and it IS the old IEGD 8.0 and the INF shows support for the 865. This file is not supported anymore so if it works great and if it does not, it might be time to update you ancient and EOL hardware.
0 포인트
JWern1
초보자
2,645 조회수
Thanks, Mr. Snarky Google User. Shockingly, I have used this Google thing before and even found the link you suggested. The readme does not list 865 support, and if one tries to run the configuration program, one finds that 865 is not a choice in the chipset selection. If you know how to use it to generate an installation for 865, or are driver savvy and can help me create one, I'd appreciate your help.
Thanks for looking into it.
0 포인트
Adolfo_S_Intel
중재자
2,645 조회수
Hello Wern
Please try selecting the 855 chipset, it is the closest one to the topology that you are using.
Adolfo.
0 포인트
JWern1
초보자
2,646 조회수
0 포인트
Adolfo_S_Intel
중재자
2,645 조회수
Hello Wern
Thanks for letting us know that the 855 option solved your issue, it is important to us when we receive feedback from the members of the community.
And thank you very much for your kind words
Adolfo.
0 포인트
응답
