IEGD Driver on 64bit Linux
BChri7
I have the IEGD driver working correctly on a 32 bit CentOS 5.2 installation but I cannot install the driver on a 64 bit version of the OS. When I load the module the machine crashes. I cannot find any mention in the documentation of 64bit Linux support.
My question is, is the IEGD driver supposed to be able to be installed on a 64bit linux system?
Brad
FMcNu1
Valued Contributor I
Hi BradC:
Welcome to the Intel® Embedded Design Center Community. To channel you to the best point of support for your question, can you please advise which Intel® processor and chipset hardware combination you are targeting?
Felix
BChri7
Thanks for the response. We are deploying our software on servers with the following CPU / chipset:
CPU: Intel® Core™ 2 Duo T7500
Chipseto Northbridge: Intel® 965GME Expresso Southbridge: Intel® ICH8M-E (Enhanced)
They are being supplied by MEN Micro, full product specificationare at: http://www.men.de/download/pdf/datasheet/02f018-ds.pdf
Brad
FRauh
Hi Brad,
I forwarded your question to our developer and he´ll have a look into this issue.
bye
Florian
Customer Support
MEN Mikro Elektronik GmbH
Message Edited by Florian on 06-24-2009 07:09 AM
FRauh
Dear Brad,
we did some research today and neither in the INTEL Download Center nor in the IEGD documentation 64bit support is mentioned. I assume you already had a look there too. We contacted INTEL directly and our distributer today for further assistance.
I´ll keep you informed here...
Florian RauhCustomer SupportMEN Mikro Elektronik GmbH
BChri7
Hi Florian,
Thanks for looking into this. I had already looked through all the IEGD documentation etc and have tried installing the 32bit binaries without luck (as expected). I have dealt directly with MEN while on this project through Mathias Beer and he knows all the details of the project.If you wish to contact me directly, my email address is brad.christiansen at thalesgroup.com.au.
Cheers,
Brad
FRauh
Hello Brad
I received the following message from INTEL this morning:
"IEGD doesn't support 64bit Linux distributions and officially, IEGD doesn't support and isn't validated for CentOS*. At times, customers can get non-supported distributions to function, but there isn't any support if there are problems.I'll close this issue now as 64bit Linux isn't supported."
Florian Rauh
BChri7
Thanks very much for chasing this up for me.
Brad
