1239 Discussions
IS SATA on Braswell Can adjusted as covered in the RX (Receive) ModPHY Register section
WChan5
Does Braswell has some Related documents about SATA RX (Receive) ModPHY Register section ?
Like SKYLAKE Can Adjustment SATA RX CTLE (As shown below)
CarlosAM_INTEL
Hello, waynechang:
In order to be on the same page, could you please tell us if this request is related to a technical problem? In case that your answer is affirmative, please give us a detailed explanation of the issue.
Waiting for your answer.
Carlos_A.
WChan5
Hello Carlos A
Thanks For your replay
In the Case,sometimes we Found A kind of brand SSD will not be Identification on Braswell motherboard
We had Try to Used this SSD on SKYLake motherboard,and test IEMT Tool
The results show that this SSD Can't Pass the Test When The RX (Receive) Over 4.0dB.
So We want to Check the RX (Receive) on our Braswell motherboard setting
1.How Can i find the RX (Receive) ModPHY Register section on Braswell ?
2.Can the RX (Receive) be modify on Braswell?
Best regards
CarlosAM_INTEL
Hello, waynechang:
Thanks for your update.
Based on your previous communication and in order to have a better idea of this situation, could you please try to reproduce the issue using SSDs from different manufacturers and models? Please let us know the results of this suggestion.
Thanks in advance for your answer to the previous question.
Carlos_A.
WChan5
Hello Carlos_A
We Had test the Other SSD in the test Before.
The other manufacturers SSD test on SKYLake motherboard can Pass The IEMT test over then 8.8 dB
But We Still Want to Know can Braswell modify the RX (Receive) or not .
Because if the Issue is from Our Customer, If they Don't want to change the SSD
We need to find the solution to solve it .
CarlosAM_INTEL
Hello, waynechang:
Thanks for your reply.
Reviewing your previous communication, this problem seems to be related to a specific SSD. Due to this fact, we suggest you contact the manufacturer of the unidentified device to find the solution to this problem.
We hope that this information may help you.
Carlos_A.
