Intel Gordon Ridge Apollo Lake
SAdir
How to boot into ABL (ABL prompt)? After flashing linux (Yocto Build) the board does an auto-boot. But right now, trying some development work with it, need to login to ABL prompt. Tried setting DIP switch 1 to off and boot. But not working. Please help.
CarlosAM_INTEL
Hello, sriniadiraju:
The information that may help you is stated in section 3.7, specifically in the first note of the third step, on page 19 of the https://cdrd.intel.com/v1/dl/getContent/567191 Gordon Ridge Modular Reference Board (MRB) Getting Started Guide document # 567191.
This document is accessible to you using the Resource & Design Center (RDC) privileged account.
In case that you want an RDC account, please request it by filling out the https://www-ssl.intel.com/content/www/us/en/forms/design/contact-support.html Resource & Design Center Account Support form.
We hope that this information may help you.
Carlos_A.
SAdir
Hi Carlos_A
I've read the document, but it does'nt say anything about working with ABL moreover the document does'nt contain a section 3.7.
I've crossed the first hurdle though, but right now having some issues with flashing images from SD-card specifically getting this error
abl-APL: rel.1721
CPU: APL-D0 [4C @ 1900MHz: premium SKU], ucode rev.24; power-on reset
CSE: FW 3.0.20.1182, SB: OFF
CSE: boot dev # 2: SPI
IPC config: R.<28 bytes> (11ms)
PCB # B00F: GR MRB (BMP fab.E, 4x16Gb); BM:1400
MRC: [v0.56.35/89.18] FB OK(0): 8GB
CSE: send DID UMA @10000000, 34MB
>>> boot sdc1:/abl64
SD: 0G, boot 0/0 [? SDR25 FW 0.0 56 5/16]: *** load err # -3
command failed(-9)
Could you help on this?
CarlosAM_INTEL
Thanks for your reply.
We suggest you review as a reference the information stated in section 4.5, on pages 22, 23, and 24 of the https://cdrd.intel.com/v1/dl/getContent/572371 Gordon Peak Automotive Boot Loader (ABL) Configuration Guide document # 572371.
We hope that this information will be useful to you.
Carlos_A.
SAdir
Hi Carlos_A
Thanks for the document. But this document does'nt describe any error codes. The log, that I've posted above has some error codes explanation to those would help me debug.
Could you help in understanding the error codes?
CarlosAM_INTEL
Thanks for your update.
We suggest you address your consultations stated in your last communication to the Evaluation Kit mailto:[email protected] Contact Customer Support email address.
We hope that this information may help you to solve this inconvenience.
Carlos_A.
