Intel® SCH US15WPT
YB
I would like to know if the baking quality of US15WPT chipset will be affected in the-10 degree oven. Also what is the minimum baking tolerance?
I am not able to obtain this info as I could not find any related datasheet in Intel RDC.
Thank you.
CarlosAM_INTEL
Hello, @YB:
You should review the information stated in section 8.4.3, on pages 15, 16, and 17 of Chapter 8 Moisture Sensitivity/Desiccant Packaging/Handling of PSMCs of the Intel Packaging Databook that can be found on the following website:
https://www.intel.com/content/dam/www/public/us/en/documents/packaging-databooks/packaging-chapter-08-databook.pdf
@CarlosAM_INTEL.
CarlosAM_INTEL
Hello, @YB:
@CarlosAM_INTEL.
YB
Thank you @CarlosAM_INTEL ,
Can I have the datasheet for this chipset?
Thank you.
CarlosAM_INTEL
Hello, @YB:
Thanks for your reply.
You can find the Intel® System Controller Hub (Intel® SCH) External Design Specification (EDS) document # 364236 when you are logged into your Resource and Design Center (RDC) privileged account on the following website:
https://cdrdv2.intel.com/v1/dl/getContent/364236
You should fill out the form stated on the following website when you have problems with the provided website or want to update your RDC account:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
You should know that we are confused, you reviewed the Datasheet as is stated in your first communication, but you are requesting it in your last message.
@CarlosAM_INTEL.
