1223 Discussions
Multi-channel power management IC (PMIC) to Intel Atom X3930
Idanavni
Hello all,
I am looking for an alternative for IDT91E0 PMIC.
I found the TPS65094 series from TI however, this component also has a sourcing problem.
I wonder if there are some other alternatives that I missed.
Thanks a lot.
Idan
Hugo_Intel
Hello @Idanavni
Thank you for posting on the Intel communities.
We will move your question to the correct sub-forum, the team in charge will get back to you soon.
Hugo O.
CarlosAM_INTEL
Hello, @Idanavni:
You need to update your profile to the premier option to help you. You should fill out the form stated on the following website:
https://www.intel.com/content/www/us/en/forms/developer/premier-registration.html
You should use a business email address to evade any inconvenience. Please avoid the free email provider's address (such as the one provided by Hotmail, Gmail, Yahoo, or others).
@CarlosAM_INTEL.
