1253 Discussions
Query about PCI enumeration in UEFI(MinnowBoard)
SP8
Hi All,
We are using MinnowBoard as a reference and Minnow UEFI as a firmware for one of our custom board.
We have a PCIe-PCI bridge connected to PCIe port 1 [00|18|00] of Atom E6xx. On the other side of PCIe to PCI bridge, we have a FPGA device which identifies itself as a PCI device using a IP core.
During EFI PCI enumeration, resource is not allocated for the FPGA(PCI) device(requests 256MB of Memory space via BAR). Why resource allocation has not happened for the PCI (FPGA) device?
If a new on-board PCI device is added, do we have to do any configuration in EFI, to support that device?
Please help on this to fix this issue. Attached the logs and setup diagram.
Natalie_Z_Intel
Hello, Sreejith! We have not forgotten you; we are tracking down answers for you. Hope to have more information tomorrow. Thank you for your patience. Lynn
RWata1
This is just a guess, since I don't know the details on the BIOS you're using, but I would assume the issue is the size of the memory space request (256 MB). You can find out the maximum size empirically by reducing the size of the memory space request, until the BIOS successfully grants it. The BIOS would have to be modified to increase this maximum.
Hope that helps,
Ross
Casey_H_Intel
Hello Sreejith,
The original design manufacturer (ODM) for the Minnowboard is Circuitco:
http://circuitco.com/ http://circuitco.com/
Because your questions are specific to the board design and system BIOS, the ODM should have the information being sought.
Casey H.
Natalie_Z_Intel
Also support can be found http://www.minnowboard.org/ Minnowboard.org. There is community participation, http://www.minnowboard.org/technical-features/ technical features, wiki, and documents. Hope this helps! Lynn
