Tizen 3.0 for atom Z3735
skris10
Hi ,
I took a tablet with Atom Z3735 available in the market and trying to port Tizen 3.0 in to it. I could see tizen 3.0 IVI is built for atom 3827. So I tried to do a USB boot using pre-built image on my tablet but I don't see any display and tried with HDMI still no luck. My question here is
How can I see the kernel logs
Do we have any Tizen source code for Z3735 or any link/doc guide me to port Tizen for Z3735 chip
whether the Tizen 3.0 IVI developed for 3827 kernel compatible with Z3735? If I want to change how much change required, Major or minor changes.
much appreciated for your king help
Gabriel_T_Intel
Hello Sudhakar,
Welcome to the Intel Embedded Community,
We are checking your case and we will be in contact with you as soon as possible,
Gabriel Thomas
Sergio_V_Intel
Hello Sudhakar,
Unfortunately the BayTrail Z3745 Bay Trail -T is on the "off-roadmap" and its support is for limited manufacturers. For this reason, we do not have support for this processor.You should be working with an ISV, if not you may need to get support thru the codec vendor (TI). Click on http://ark.intel.com/compare/80273,80272,80274,80275 this link to learn more about the specifications of the Z3735 family.
Sergio
skris10
Thanks a lot for quick reply. Do you have any linux kernel for this chip?
Adolfo_S_Intel
Hello sudhakar
As you can see on the following page: https://www-ssl.intel.com/content/www/us/en/processors/atom/atom-z3700-consumer-tablets-brief.html Intel® Atom™ Processor Z3700 Series for Consumer Tablets: Brief , Baytrail Z37XX series, was designed for Windows 8, Tablet market, no other distribution is officially supported by Intel.
My guess is that probably any newer Linux distribution will supported, but I can't guarantee that all the drivers will be supported.
The Yocto Project also has a generic kernel for Intel platforms that could be of interest to you: https://www.yoctoproject.org/downloads/bsps/daisy16/generic-x86-and-generic-x86-64 https://www.yoctoproject.org/downloads/bsps/daisy16/generic-x86-and-generic-x86-64 please bear in mind that Yocto is not supported on this channel, so if this option is of interest to you, you should use the Yocto support channels.
Adolfo.
