1229 Discussions
Trouble enumerating PCIe devices on 1-n450 devboard
MHirs1
I have an 1-n450 devboard (atom processor card and miniitx carrier board). The carrier board has a PCIe x16 size connector. I am not able to enumerate any PCIe cards in this slot. I am running Fedora 19 Linux. I've tried older versions of Fedora, all with the same result. The lspci command finds all the internal devices but not the card in the carrier board PCIe slot.
I reset the CMOS settings to factory default, and have attached the lane setup jumper to attach all 4 PCIe lanes to the carrier board connector. I've tried two different PCIe devices: one PCIe 1x video capture card, and one PCIe 16x nvidia quadro card. Both of these cards are enumerated in other systems.
How can I debug this? Are there non-default BIOS that I ought to be setting? Should I be booting from UEFI instead of BIOS?
Matt
Natalie_Z_Intel
Hello! I believe an answer is forthcoming! Stay tuned. I just wanted you to know that we are working on this.
Natalie_Z_Intel
Hello! I have located someone within Intel who is going to set up a system and test this. Hope to have the results soon!
Natalie_Z_Intel
I checked with my contact and he is hoping to have an answer for you next week.
MHirs1
Thanks for looking into it Lynn. I'm eagerly awaiting an answer
FrankVanWeerdenburg
Hello Matt,
You might like to check the BIOS setting: ACPI Support, which should be enabled.
Frank
MHirs1
Frank,
Thanks for the suggestion. I tried both with and without ACPI support. No change.
Matt
JOHAN_V_Intel
Hi Matt,
I have verified on a N-470 Devboard that the PCIe slot on the carrier is functional as a X4 when configured through BIOS as a by x4 ... You can configure it to a X4 mode by going to the South bridge setup option and there you will find an option to set lanes by jumper, or select the actual combination of PCIe slots you would like .... For your application, I would recommend that you select X4 for a graphics card. I tested an Intel 10 Gbe NIC card in the slot and it enumarated with no issues at all.
Another option to check whether the card is being detected (but not recognized due to drivers) is by booting to the EFI shell. There is a command pci that will list all the pcie devices that it detects.
My experiements were done with Windows 2012 and linux
Please post the output of lspci -vvv ... I would like to confirm that Linux recognized the PCIe configuration ...
Johan
MHirs1
Johan,
Thanks for checking this. Unfortunately, I don't know what to do with a "it works for me". I've already stated that the lspci command doesn't show any device connected to the carrier PCIe slot, which has nothing to do with whether a driver is loaded.
I have checked in the BIOS that the system has correctly detected the jumper selecting 4x mode. I don't have the board in front of me at the moment, so I can't post the exact output of lspci, but I can tell you that none of the devices I plugged into the PCIe slot show up in the lspci list. I have also already loaded the UEFI firmware and found that only the onboard devices show up in the list generated by the "pci" command -- nothing in the carrier PCIe slot. Having verified the same problem in the UEFI shell, I don't think this is an issue with linux.
Can you tell me what version of the system BIOS you are using? I might chalk it up to faulty hardware on my end, but we both see that someone else on this board was having the same problem. Also, have you tested this with a non-intel PCIe card? I noticed that all of the hardware vendor IDs enumerated on the board are intel, and you said you used an Intel NIC. Maybe no one ever tried it with non-intel PCIe hardware?
Thanks again for checking.
JOHAN_V_Intel
Hi Matt ...
What I mean by "it works for me" is the following:
The 1st thing I looked for was whether the strap or BIOS setting was configuring the chipset's PCIe lanes correctly. It is not as easy in Linux, but lspci -vvvv will show you each of the PCIe ports available and there width (x1, x2 or x4). This checked out correctly.
The second step was I plugged in a Intel 10Gbe X8 network adapter and validated that it was detected and that it trained to the correct number of PCIe lanes (i.e. X4 , X2 or X1) ...
We have tried non-Intel Hardware other than NICs when we validated the design ... If you can provide the lspci -vvv output for me that will be extremely helpful ...
Johan
MHirs1
# lspci -vvv
00:00.0 Host bridge: Intel Corporation Atom Processor D4xx/D5xx/N4xx/N5xx DMI Bridge
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- SERR-
Latency: 0
Capabilities: [e0] Vendor Specific Information: Len=08 <?>
Kernel driver in use: agpgart-intel
00:02.0 VGA compatible controller: Intel Corporation Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller (prog-if 00 [VGA controller])
Subsystem: Intel Corporation Device 1999
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0
Interrupt: pin A routed to IRQ 42
Region 0: Memory at 50280000 (32-bit, non-prefetchable) [size=512K]
Region 1: I/O ports at 3140 [size=8]
Region 2: Memory at 40000000 (32-bit, prefetchable) [size=256M]
Region 3: Memory at 50000000 (32-bit, non-prefetchable) [size=1M]
Expansion ROM at [disabled]
Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
Address: fee0100c Data: 4171
Capabilities: [d0] Power Management version 2
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Kernel driver in use: i915
00:02.1 Display controller: Intel Corporation Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0
Region 0: Memory at 50200000 (32-bit, non-prefetchable) [size=512K]
00:19.0 Ethernet controller: Intel Corporation 82567V-3 Gigabit Network Connection (rev 04)
Subsystem: Intel Corporation Device 0000
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- SERR-
Latency: 0
Interrupt: pin A routed to IRQ 43
Region 0: Memory at 50300000 (32-bit, non-prefetchable) [size=128K]
Region 1: Memory at 50324000 (32-bit, non-prefetchable) [size=4K]
Region 2: I/O ports at 30c0 [size=32]
Capabilities: [c8] Power Management version 2
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee0100c Data: 41a1
Kernel driver in use: e1000e
00:1a.0 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller # 4 (rev 04) (prog-if 00 [UHCI])
Subsystem: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller # 4
Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- SERR-
Latency: 0
Interrupt: pin A routed to IRQ 16
Region 4: I/O ports at 30a0 [size=32]
Kernel driver in use: uhci_hcd
00:1a.1 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller # 5 (rev 04) (prog-if 00 [UHCI])
Subsystem: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller # 5
Latency: 0
Interrupt: pin B routed to IRQ 21
Region 4: I/O ports at 3080 [size=32]
00:1a.7 USB controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller # 2 (rev 04) (prog-if 20 [EHCI])
Subsystem: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller # 2
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- SERR-
Latency: 0
Interrupt: pin C routed to IRQ 18
Region 0: Memory at 50325400 (32-bit, non-prefetchable) [size=1K]
Capabilities: [50] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Capabilities: [58] Debug port: BAR=1 offset=00a0
Kernel driver in use: ehci_hcd
00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 04)
Subsystem: Analog Devices Device 989b
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 10
Region 0: Memory at 50320000 (64-bit, non-prefetchable) [size=16K]
Flags: PMEClk- DSI- D1- D2- AuxCurrent=55mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Capabilities: [60] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [70] Express (v1) Root Complex Integrated Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
ExtTag- RBE- FLReset-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port # 0, Speed unknown, Width x0, ASPM unknown, Latency L0 <64ns, L1 <1us
ClockPM- Surprise- LLActRep- BwNot-
LnkCtl: ASPM Disabled; Disabled- Retrain- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed unknown, Width x0, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
Capabilities: [100 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
V...
JOHAN_V_Intel
Hi
Thanks for the information ...
a) Did you have a card plugged into the PCIe slot? From the dump above, the port is configured as a x4 which is what would be expected ...
b) Can you tell me how the LANE SETUP jumper is configured ... details can be found in the user-guide ...
https://www-ssl.intel.com/content/www/us/en/intelligent-systems/luna-pier/edb-1-n450-1-d510-user-guide.html Intel® Embedded Development Board 1-N450/1-D510: User Guide
Johan
