1230 Discussions
Unable to add Intel driver to Windows embedded image
VYadl
I am running into an issue with an out of box driver. I added the out of box driver under offline servicing phase and created IBW image from answer file. Copied the image to a USB and tried booting from USB. The installation goes fine however the driver does not get installed. I get the following log in cbs_unattend.log that I collected after installation
2012-04-03 00:18:24, Error DISM DISM Driver Manager: PID=1884 Failed to find driver packages at 'D:\\AutoUnattend_Files\offlineServicing\Out-of-Box Drivers\Intel\Montevina(Cantiga-Chipset)-Intel(R)_85277_GbE_LAN-Drivers\14.8\x86' ( HRESULT = 0x80070003 ) - DriversCallback
I have also copied the hardware id part from e1y6232.inf file which shows that the inf file is compatible with this controller
[Intel.NTx86.6.1.1]
; DisplayName Section DeviceID
%E10F5NC.DeviceDesc% = E10F5, PCI\VEN_8086&DEV_10F5
%E10F5NC.DeviceDesc% = E10F5, PCI\VEN_8086&DEV_10F5&SUBSYS_10F58086
%E10F5NC.DeviceDesc% = E10F5, PCI\VEN_8086&DEV_10F5&SUBSYS_00011179
%E10BFNC.DeviceDesc% = E10BF, PCI\VEN_8086&DEV_10BF
%E10BFNC.DeviceDesc% = E10BF, PCI\VEN_8086&DEV_10BF&SUBSYS_10BF8086
%E10BFNC.DeviceDesc% = E10BF, PCI\VEN_8086&DEV_10BF&SUBSYS_00011179
%E10BFNC.DeviceDesc% = E10BF, PCI\VEN_8086&DEV_10BF&SUBSYS_00021179
%E10CBNC.DeviceDesc% = E10BF, PCI\VEN_8086&DEV_10CB
%E10CBNC.DeviceDesc% = E10BF, PCI\VEN_8086&DEV_10CB&SUBSYS_10CB8086
%E10CBNC.DeviceDesc% = E10BF, PCI\VEN_8086&DEV_10CB&SUBSYS_00011179
%E10CCNC.DeviceDesc% = E10CC, PCI\VEN_8086&DEV_10CC&SUBSYS_10CC8086
%E10CDNC.DeviceDesc% = E10CD, PCI\VEN_8086&DEV_10CD&SUBSYS_10CD8086
%E10CENC.DeviceDesc% = E10CD, PCI\VEN_8086&DEV_10CE&SUBSYS_10CE8086
%E10E5NC.DeviceDesc% = E10CC, PCI\VEN_8086&DEV_10E5
%E1501NC.DeviceDesc% = E10CD, PCI\VEN_8086&DEV_1501
I have copied the relevant log from the setupapi.dev.log. However after the installation completes if I do update driver from device manager and point the location to the USB. The driver gets installed. Any help is highly appreciated
>>> [Setup online Device Install (Hardware initiated) - pci\ven_8086&dev_1501&subsys_00008086&rev_04\3&33fd14ca&0&c8]
>>> Section start 2012/03/31 00:11:47.625
ump: Creating Install Process: DrvInst.exe 00:11:47.625
ndv: Retrieving device info...
ndv: Setting device parameters...
ndv: Searching Driver Store and Device Path...
dvi: {Build Driver List} 00:11:47.640
dvi: Searching for hardware ID(s):
dvi: pci\ven_8086&dev_1501&subsys_00008086&rev_04
dvi: pci\ven_8086&dev_1501&cc_020000
dvi: Searching for compatible ID(s):
dvi: pci\ven_8086&dev_1501&rev_04
dvi: pci\ven_8086&cc_020000
dvi: pci\ven_8086
dvi: pci\cc_020000
dvi: pci\cc_0200
cpy: Policy is set to make all digital signatures equal.
dvi: Enumerating INFs from path list 'C:\Windows\inf'
inf: Searched 0 potential matches in published INF directory
inf: Searched 18 INFs in directory: 'C:\Windows\inf'
dvi: {Build Driver List - exit(0x00000000)} 00:11:48.375
ndv: Selecting best match from Driver Store (including Device Path)...
dvi: {DIF_SELECTBESTCOMPATDRV} 00:11:48.437
dvi: No class installer for 'Ethernet Controller'
dvi: No CoInstallers found
dvi: Default installer: Enter 00:11:48.437
dvi: {Select Best Driver}
! dvi: Selecting driver failed(0xe0000228)
dvi: {Select Best Driver - exit(0xe0000228)}
! dvi: Default installer: failed!
! dvi: Error 0xe0000228: There are no compatible drivers for this device.
dvi: {DIF_SELECTBESTCOMPATDRV - exit(0xe0000228)} 00:11:48.484
ndv: Waiting for previous device install to complete. 00:11:48.484
ndv: {Core Device Install} 00:11:49.640
! ndv: Installing NULL driver!
dvi: Set selected driver complete.
dvi: {DIF_ALLOW_INSTALL} 00:11:49.875
dvi: Default installer: Enter 00:11:49.875
dvi: Default installer: Exit
dvi: {DIF_ALLOW_INSTALL - exit(0xe000020e)} 00:11:49.875
dvi: {DIF_INSTALLDEVICE} 00:11:49.875
dvi: Default installer: Enter 00:11:49.890
! dvi: Installing NULL driver!
dvi: Writing common driver property settings.
dvi: {Restarting Devices} 00:11:49.906
dvi: Restart: PCI\VEN_8086&DEV_1501&SUBSYS_00008086&REV_04\3&33FD14CA&0&C8
dvi: Restart complete.
dvi: {Restarting Devices exit} 00:11:50.046
dvi: {DIF_INSTALLDEVICE - exit(0x00000000)} 00:11:50.046
Vijay
