1266 Discussions
Yocto-generated image does not pass the systemd-boot bootloader
lucas8456
Good morning,
I generated a Linux Image by following the document number 619566-3.4 (Yocto Project*-based Board Support Package for Intel Atom® x6000E Series, and Intel® Pentium® and Celeron® N and J Series Pro).
I built option C (mc:x86-2021-minimal:core-image-full-cmdline) using bitbake. And used bmaptool to prepare a bootable image (differently from the guide, in my case the `.wic.bmap` file was not generated, only the .wic, so I had to pass the --nobmap option to bmaptool).
The Elkhart Lake CRB recognizes the bootable image, and boots into systemd-boot.
After selecting the only option in the systemd-boot bootloader, the following message is displayed: "EFI stub: Loaded initrd from command line option", and the boot process does not go any further, being stuck on a screen with this message.
I have tried, however, this same image on my desktop (a Xeon E5-2650 V3) and I can boot til the login screen and log into root. I can also test the image on qemu. But the boot process fails on the CRB.
What could be possibly hapenning?
Do I have to set something up in the bios menu?
lucas8456
Bump.
Jaime_Lizarme
Hello @lucas8456 ,
Yocto questions are addressed through the following community and mailing list:
https://www.yoctoproject.org/community/mailing-lists/
Jaime L.
