braswell enable/disable pci device
sbass
i try activated pci device 28 function 0 , 22C8h pcie Port 1:
i use register: Function Disable (FUNC_DIS)—Offset 34h
FUNC_DIS_BITS bit 20 - PCIE* function 0 set 0.
After write bit 20 set to 0, i read this register and this bit always 1.
Can you enable pci device by this register ?
is there another solution for activate this pci device (device 28 function 0 , 22C8h pcie Port 1) ?
Sébastien
Adolfo_S_Intel
Hello keziaha
Could you please let me know how are you changing the state of the bit?
Are you using a third party program? Are you developing your own application?
What operating system are you using?
Are you using your own board or a third party board?
I will be waiting for your feedback.
Adolfo Sanchez
sbass
Hello Adolfo,
We have design our board with braswell cpu, for boot i use coreboot + fsp.
I develop in coreboot, so i write directly in register :
pmc_base + func_dis: 0xfed03000 + 0x34 set bit 20 for pcie function 0
My goal is pcie port 1 (function 0) is always enable, power on , even without device connected on line pci.
Sébastien
CarlosAM_INTEL
Hello, keziaha:
Thanks for your reply.
The information that may help you as a reference is stated at:
https://mail.coreboot.org/pipermail/coreboot-gerrit/2015-November/036179.html https://mail.coreboot.org/pipermail/coreboot-gerrit/2015-November/036179.html
https://github.com/coreboot/coreboot/blob/master/src/soc/intel/braswell/include/soc/pcie.h coreboot/pcie.h at master · coreboot/coreboot · GitHub
https://github.com/coreboot/coreboot/blob/master/src/soc/intel/braswell/pcie.c coreboot/pcie.c at master · coreboot/coreboot · GitHub
We hope that this information may help you.
Carlos_A.
sbass
here my trace :
src/soc/intel/braswell/chip.c/enable_dev ( Intel Braswell SoC ), type: 2
vendor: 0xffff. device: 0xffff
class: 0xff Unassigned class
subclass: 0xff ???
prog: 0xff
revision: 0xff
src/soc/intel/braswell/southcluster.c/southcluster_enable_dev ( Intel Braswell SoC )
PCI: Static device PCI: 00:1c.0 not found, disabling it.
PCI: 00:1c.0 [ffff/ffff/00ffff] has unknown header type ff, ignoring.
PCI: 00:1c.0 [ffff/ffff] enabled No operations
pci_probe_dev dev
pci_probe_dev enable device
vendor: 0x8086. device: 0x22ca
class: 0x06 Bridge
subclass: 0x04 PCI bridge
prog: 0x00
revision: 0x35
PCI: 00:1c.1 [8086/0000] bus ops
src/soc/intel/braswell/pcie.c/pcie_enable ( Intel Braswell SoC )
src/soc/intel/braswell/pcie.c/check_port_enabled ( Intel Braswell SoC )
src/soc/intel/braswell/pcie.c/check_device_present ( Intel Braswell SoC )
PCI: 00:1c.1 [8086/22ca] enabled
pci_probe_dev dev
i don't see vendor id and device id of device port 1:
Why ? device pcie port 1 is disable before?
On device port2 we see vendor id and device id , pcie_enable is launched after .
CarlosAM_INTEL
Hello, keziaha:
In order to provide the proper support, could you please answer the questions stated in our communication of the past May 9th, 2017 specifically at 2:03 PM?
Waiting for your reply.
Carlos_A.
sbass
--> pmc_base + func_dis: 0xfed03000 + 0x34 set bit 20 for pcie function 0
--> i use coreboot + fsp intel.
--> no operating system.
--> we have our own board.
CarlosAM_INTEL
Hello, keziaha:
Thanks for your update.
The information that may help you, which must be reviewed with the assistance of your BIOS vendor, is stated in sections 37.3 and 37.2, on pages 387 and 386 of the https://edc.intel.com/Link.aspx?id=10022 Braswell System-on-Chip (SoC) BIOS Writers Guide document # 541233.
We hope that this information is useful to you.
Carlos_A.
sbass
Carlos,
Ok, but, i don't have bios vendor but i use FSP INTEL for braswell with coreboot. In coreboot no code corresponding " Root Ports Function Disable Flow". For me it's FSP disable root port. But i don't have souce code . fsp take in input device tree, there is maybe an solution for not disable root port?
And in datasheet, i don't have description register :
D28:Fn + 0x420
D28:Fn + 0xF4
D28:Fn + 0x338
D28:Fn + 0xE0
D28:Fn + 0x408
Otherwise, Can we enable root ports after disable this root Ports ?
Sébastien
CarlosAM_INTEL
Hello, keziaha:
In order to help you, we will send an email.
Carlos_A.
