1267 Discussions
check difference between FH8065301487717S R3UT & FH8065301487719S R3UU
JLiu18
Hi There,
Could you help check and advise the difference between above two parts?
Jaime_Lizarme
Hi   @JLiu18 ,
Both parts belong to the same CPU, Baytrail E3845, unfortunately this product has reached End of Servicing therefore its documentation is no longer available; however, the difference might be the stepping.
Jaime L.
