1230 Discussions
how to change the OS in atom E6xx tunnel creek board using BLDK??
How to change the OS in atom tunnel creek board E6xx??. Currently I am having debian OS as the default OS. I need to tweak the OS for my application. Please help.
FMcNu1
Valued Contributor I
Hello:
Here is some information from Intel's BLDK experts:
BLDK is not dependent on the OS, but rather the OS Loader. If you use a supported OS loader in the OS, such as ELILO or GRUB2, then your Linux OS should boot fine from BLDK.
The GRUB for UEFI is EFISTUB. You can try that. You can refer to some of these links
https://git.kernel.org/?p=linux/kernel/git/torvalds/linux.git;a=blob_plain;f=Documentation/x86/efi-stub.txt;hb=HEAD https://git.kernel.org/?p=linux/kernel/git/torvalds/linux.git;a=blob_plain;f=Documentation/x86/efi-stub.txt;hb=HEAD
https://wiki.archlinux.org/index.php/UEFI_Bootloaders https://wiki.archlinux.org/index.php/UEFI_Bootloaders
Note that BLDK does not support an OS installation . You have to create the OS image first, then flash the BLDK boot loader to your platform, then boot the OS image.
I hope this helps.
Felix
J. Felix McNulty
Community Moderator
FMcNu1
Also check out this thread that has some links to docs about OS installation on this development board
/message/7712# 7712 http://embedded.communities.intel.com/message/7712# 7712
Felix
my tunnel creek board has bootloader in it. It has fedora timesys 11 OS. I cant boot other than that.
