公告
1258 討論
".NET Check failed"? Unattended install Q graphics "Intel HD graphics"
EPatt
初學者
2,664 檢視
Hello, I'm trying to install the Q57 video drivers using an unattended install and it fails every time with the message "Checking .NET configuration" "* .NET check failed"
I do not care about .NET at the point in the build that I am installing the video drivers, how do I tell the setup to shut up and install? Is there a /shutupabout.NETalreadyandinstall switch?
This is for a Windows XP build. I don't want to install .NET since it gets installed later in the process.
0 積分
1 回應
FMcNu1
傑出貢獻者 I
1,811 檢視
Hello, EricPatterson:
Welcome to the Intel® Embedded Community.
Are you working with an embedded system, or a consumer PC?
If you haven't already done so, you might want to check out this support area for the Q57:
http://www.intel.com/p/en_US/support/highlights/chpsts/5series-chpsts http://www.intel.com/p/en_US/support/highlights/chpsts/5series-chpsts" target="_blank" rel="nofollow">http://www.intel.com/p/en_US/support/highlights/chpsts/5series-chpsts
Felix
回覆
