Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
ARM tools for 82574
DDesa3
Hi - We have a few questions regarding the 82574:
1. We would like to flash the 82574 on an ARM machine but cannot find any ARM binaries for tools such as LANConf. Where can we find tools for an ARM platform?
2. Where can we get access to the latest production flash image for the 82574?
3. We have an external flash connected to the 82574 and no eeprom. However, the LANConf tool is showing both eeprom and flash. Additionally, we are able to clear both, but after power cycling the eeprom is repopulated with the data from before we erased it. We are unable to find anything in the datasheet explaining this behavior; is it expected?
Thank you!
CarlosAM_INTEL
Hello, dileep:
The https://cdrdv2.intel.com/v1/dl/getContent/377520 Intel 82574 Gigabit Ethernet Controller Production Sample Validation Kit [SVK] Silicon Sample Kit document # 377520 contains EEPROM/NVM Images. This document is accessible when you are logged into your Resource & Design Center (RDC) privileged account. It can be requested by filling out the https://www.intel.com/content/www/us/en/forms/design/contact-support.html RDC Account Support form.
In order to help you with the rest of your consultation, we will contact you via email.
We hope that this information may help you.
Carlos_A.
DDesa3
Thank you for your help! We're having some problems with the eepromARMTool that you sent us. We have a Winbond W25X40BVNIG flash connected to the 82574. Running ./eepromARMtool -dump -NIC=1 gives us a file whose first line is:
8888 8888 8887 0C20 F746 2014 FFFF FFFF
We want to change the MAC address, so we edit the file that was dumped and change the first line to:
70B3 D501 C307 0C20 F746 2014 FFFF FFFF
Then we run ./eepromARMtool -write -NIC=1 -f=new_mac.otp. If we run the dump command again, the flash appears to have the correct contents. However, if we reboot or power cycle the machine and dump again, the output has returned to its original contents. This seems to imply that our changes were not actually flushed to the flash. Do you have any advice for how to fix this problem?
Thank you!
CarlosAM_INTEL
Hello, dileep:
Thanks for your reply.
Could you please confirm us if the cited situation happens when you use thehttps://cdrdv2.intel.com/v1/dl/getContent/572162 Intel I210, I211, and X550 EEPROM Access Tool (EAT) document # 572162?
This tool is accessible when you are logged into your Resource & Design Center (RDC) privileged account. It can be requested by filling out the https://www.intel.com/content/www/us/en/forms/design/contact-support.html RDC Account Support form.
Waiting for your answer to this question.
Carlos_A.
DDesa3
The same problem occurred when we used the EEPROM access tool that you sent us.
CarlosAM_INTEL
Hello, dileep:
In order to be on the same page, could you please tell us if this situation is related to an add-in card? Please give us all the information if it is an add-in card.
Could you please clarify us know if it is your own design? In case that it is your design, could you please let us know the sources that you use to develop it and if it has been reviewed by Intel?
Waiting for your reply to these questions.
Carlos_A.
DDesa3
We are using an add-in card: Intel EXPI9301CT Gigabit CT PCI-e Desktop Adapter.
CarlosAM_INTEL
Hello, dileep:
Thanks for your clarification.
In order to help you with your Intel Network Adapters consultations, they should be addressed to the https://communities.intel.com/community/tech/wired Intel Wired Ethernet Community.
We hope that this information may help you to solve your problem.
Carlos_A.
